(Topic ID: 232397)
Bally gold ball solenoids
By wop3405
3 months ago
  • 13 posts
  • 5 Pinsiders participating
  • Latest reply 88 days ago by wop3405
    #1 3 months ago
    I just acquired a bally gold ball. Machine when turned on mpu flashes as it should and displays come on along with sound. Can add credits and push button to start a game but no solenoids fire at all. Can manually touch each target and sounds work and points add up. Any ideas on what I need to look at next? I'm new to trying to work on them. Thanks
    #2 3 months ago
    Do the flippers work but no other solenoids? If so then check the fuse under the playfield first.
    #3 3 months ago
    Flippers do not fire either nor does the ball kick out
    #4 3 months ago
    Does the flipper relay on the solenoid driver board engage in power up, you should here it click in.
    #5 3 months ago
    Not sure I'll start there. I'll update once I do
    #6 3 months ago
    Fuse under the playfield perhaps?
    #7 3 months ago
    Make sure both the balls are in the game
    #8 3 months ago
    Update
    Both balls in
    Play field fuse looks fine
    Do not hear anything kick on on solenoid driver board though
    #9 3 months ago
    Check connector at A2-J1 pin 7.
    That is the connection to the playfield for the +43V.
    A2 is the rectifier board on the bottom of the cabinet.
    Do you have 43V at the coils of the playfield?
    #10 3 months ago
    https://pinside.com/pinball/forum/topic/need-help-no-43-volts#post-4329368
    Sounds familiar to my issue. Mine was a cracked solder joint on the rectifier board
    #11 3 months ago
    If you have a meter, I think it is time to do some voltage checks.
    #12 3 months ago
    I'll check these and report back. Thanks again for the help
    3 weeks later
    #13 88 days ago
    Thanks for the help guys. It ended up being the gold ball kick out solenoid was burnt and had burnt a diode. Machine is now fully functional and being played regularly.
    $ 7,499.00
    Nitro Pinball Shop
    $ 21.99
    Playfield - Plastics
    Pinball-Mods.com
    $ 34.95
    Hookedonpinball.com
    $ 46.00
    $ 99.99
    $ 14.95
    $ 29.99
    $ 109.99
    $ 49.95
    pinballmod
    Gweem's Mods
    $ 130.00
    Rods Mods
    $ 5,799.00
    Operation Pinball
    $ 49.00
    $ 21.00
    $ 29.99
    £ 49.00
    PinballToys
    $ 49.99
    CzTV Mods
    $ 149.00
    $ 7,499.00
    Classic Game Rooms
    $ 22.00
    Yorktown Parts and Equip
    $ 9,995.00
    Flip N Out Pinball
    Great American Pinball
