Please be kind as this is my first pin I’ve worked on. I, just today acquired a Bally Gator which has a problem with the outhole. The solenoid will not activate when a ball is sitting in the hole. I can though manually hit then ball return relay and it will kick the ball out. It’s almost as if the machine is not sensing there is a ball waiting in the hole to be kicked out. I’ve taken some pictures of the switch and it seems there are two wires missing from it with no apparent cut wires anywhere that need to be reconnected. It’s my guess these wires activate the solenoid when a ball is present If you don’t mind, take a look and tell me what you think.
Also, when i hit the micro-switch in the pathway the ball will kick. Forgive me using the wrong terminology, i’m New. See picture of that as well.
Thanks in advance for any and all help.
Dave.
351D95CD-4A73-46FC-B9E7-9E1443E2D339 (resized).jpeg39A2B6D8-5324-43DD-875D-A763DCA9BB13 (resized).jpegF5DE7EA7-626B-417C-97BA-DD07E995F433 (resized).jpeg
