(Topic ID: 227285)
Bally Future Spa MPU 2 Blinks Won't Start Issue
By canoncitypb
5 years ago
#1 5 years ago
I am working on a Bally Future Spa and magically the game stopped booting up. I will get two blinks then nothing. I tested all voltages from the transformer to the rectifier board to the driver board to the MPU. All voltages seem within range.
If I unplug J2 on the MPU the board will go through all blinks at startup and will start a game, but only the flippers will work. If I ground TP7 on the MPU board (while trying to test the voltage, the game will go through the blinks and start up. However, when you play a game, the features are mixed (left kickout lane will trigger pop bumper). Once the game is up, I get the correct voltage at TP7. On the times it doesn't immediately restart when grounded, I have less voltage at TP7.
I repinned the ground and voltage sections on J4 female plug, refreshed the solder on the board at pins 18 and 19 and did a ground wire mod suggested on another site to strengthen the ground connection.
The board doesn't have any corrosion. The battery was replaced with a memory capacitor.
I replaced the 5101 at U8.
since the connector at J2 seems to be related, I was going to repin the female connector there.
I have swapped in a working rectifier, then a working driver board, then a working alltec universal MPU all with the same results.
Does anyone have any suggestions?
#2 5 years ago
I guess after thinking about it, I can't be grounding it when I am using the multimeter. Perhaps there is a charge built up that pushes the voltage over the edge. It is at 1.94 when it gets two blinks. When I disconnect J2, I get 2.84 which is much closer to the 3vdc the schematic says should be there.
Any suggestions?
#3 5 years ago
Game is behaving like something is shorted with the PIA wiring and the fact the board will boot when J2 is removed is a valuable clue. Since you know J2 does something the next step is to open up the Schematic and look at what J2 does. Looking at this myself I see J2 is the playfield switch matrix. So I would start at that wiring and look for a short. If you can't find one you may have to pull all the wires from J2 and reconnect them one by one until you narrow it down to the wire or wires that stop the board from booting.
Before doing anything though tr swapping U10 and U11 and see if that makes a difference.
#4 5 years ago
That was my next step. I repinned the female J2 plug tonight with no luck. I get the same result with my alltek board, so I am guessing it is something in the wiring.
do you mean replace u10 and u12 or remove one and put it in place of the other? Why would I do that?
thanks,
#5 5 years ago
U10 and U11 (not U12) are both the same 6821 chip. You can swap them.
#6 5 years ago
figured it out. You were right. It was a short. the roll over switch on the left side was connected to the GI lights under the sling. Once I bent those back into place, everything is fine.
Thanks for the help.
$ 18.95
$ 149.95
Allteksystems
$ 5.00
Playfield - Plastics
$ 44.00
PinballReplacementParts
$ 169.00
2,500 (OBO)
Richfield, MI
$ 17.50
$ 169.00
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 40.00
The Flipper Room
$ 9.95
$ 69.00
Pinball Pimp
$ 100.00
$ 29.00
RoyGBev Pinball
St. Louis, MO
Troxel Repair
Middletown, OH
$ 29.00
RoyGBev Pinball
Beehive Pinball Co.
$ 18.95
$ 12.00
$ 5.00
$ 55.00
Displays
PinballSolutions.eu
This page was printed from https://pinside.com/pinball/forum/topic/bally-future-spa-mpu-2-blinks-won-t-start-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
