Hi Matt
I have a vague theory. The topic is old - I kind of start at the beginning and ask: You play a ONE-Player-Game - You loose Ball-1 - does the Outhole-Relay pull-in, Ball-Index-Relay is pulling, Score-Motor turns, NO FIRING of Ball-Count-Unit-Step-UP, Player-Reset-Relay, Player-Up-Unit-Reset, Player-Up-Unit-Step-Up ? (((These words recall the JPG in post-4, green and orange-brown)))
The vague theory (my red star in JPG here) the Score-Motor-Switch-1F is faulty ALWAYS closed. And so the Outhole-Relay sometimes (odd numbers of bonus) gets activated too early compared with "even numbers do activate it at a good time".
Do not spend hours - the theory is vague, crummy --- do several times "even numbers" and look at the Score-Motor turning the bakelite wheels - also look at the Outhole-Relay pulling-in. I believe "even numbers" make the Outhole-Relay pull-in WHEN the Score-Motor is in HOME-Position (am I right ?).
Then do the faulty "odd numbers" - question: DOES the Outhole-Relay pull-in at "Score-Motor is in ANOTHER position" ?
IF (if) "ANOTHER position": Want to look at Score-Motor-Switch-1-F - does it TRUELY opens ?
I read the schematics (my JPG) as: "light-green" - "dark-green" - "light-blue" - "dark-blue".
The "Bonus-ZERO-Relay" pulls-in when the Bonus is counted down --- so Switch (my dark-blue star) is immediately thrown - BUT with an functioning SCM-1F (my red star): The Score-Motor must turn further - reaching "Home-Position" - THEN the Outhole-Relay shall pull-in.
Again - my theory is vague, crummy - do not spend hours - important is the answer to the question: Outhole-Relay pulls-in at Score-Motor-Position-XYZ. IS XYZ always "Home-Position of the Score-Motor" ? Greetings Rolf
