What were the random audit values? A partially bad 5101 RAM can be a real headache to deal with. Unless you have a RAM tester or known-good memory to swap-out, you'll be chasing your tail until you've ruled out the 5101 if there's possible memory corruption occurring. If it was me, I'd invest in some type of RAM replacement and rule that out. I've learned my lesson time and time again with classic Bally/Stern boards to not trust the 5101 RAM and have extra memory around to immediately swap in when the machine is acting funky.
At this point, IMO your options are to spend $30 on a RAM tester from http://www.neoloch.com if you want to be able to test your own RAM (incredible deal for troubleshooting) ~OR~ spend anywhere between $5 and $40 on a RAM replacement that you can swap into your board. The RAM tester will come in handy in the future if you will be staying in the hobby for a while and will quickly pay for itself in time savings. You will VERY likely be buying a new RAM chip as well if once you test your RAM it checks out bad.
So that leads to the 2nd option.. trying a new RAM IC. I'd encourage you to buy a compatible RAM adapter INSTEAD of buying another genuine 5101 RAM. The 5101 itself is very static sensitive and they're $5-8 usually + shipping for one chip.. so if you need to buy new memory you really can't justify the cost if you can't luck into a deal where you can buy 10x or so 5101 RAM at a time for a few bucks a piece. It's just not worth buying a single 5101 RAM IC and spending $10 total, to then zap it while you're using it for testing and be in the same boat again. There are many replacement adapters available that adapt much less static-sensitive RAM to a 5101 pinout, including RAM adapters that use a lithium coin cell or memory capacitor and adapt 6264 low-power RAM to 5101 pinout and NVRAM that won't require any batteries on the MPU.
Here are just a few options for 5101 RAM adapters:
http://www.pinitech.com/products/5101_budget_ram.php (6264 RAM adapter)
http://www.pinforge.com/ (NVRAM)
http://lockwhenlit.com/anyPin.htm (NVRAM)
I'm sure there are others too, Tom Callahan (Pin-Logic) used to produce a few adapters but he is recently out of the pinball parts business after 50 yrs. Just so you're aware, the Pinitech adapters are mine & are available in kit form if you want to save a few dollars and don't mind soldering. The other links are for NVRAM adapters that will rid you of batteries completely made by various pinball enthusiasts. All are excellent options and would provide a much more rugged RAM for use when troubleshooting machines since they have machine pin strips instead of the frail IC legs.
Hope that helps, not trying to steer you clear from continuing to try and troubleshoot without putting out any money, but if you'll be messing around with similar machines in the future.. a RAM tester and/or one of those 5101 RAM adapters will help immensely. I've learned over the years that test equipment or something I know is good that I can swap in/out easily is well worth the price over hours and hours of wondering what that little black box is doing.
