A wiseman by the name of Shock me gave me this priceless information, it may help you also good luck
Quick Google search:
After power-up and the correct reset timing/voltage regulation, the LED briefly
flickers (for approx 300 milliseconds) before;
*1st flash*
The test program attempts to validate the condition of the 128 bytes of NMOS
RAM located at page zero - address $0000 through $007F. Note that I haven't
said "the test program attempts to test the RAM at U6" - why? Because Bally
made an oversite with the test documentation.
If you have a 6802 installed in your S+T then the *internal* 128 bytes of
RAM are tested and *not* U6 providing the 680x's RAM Enable line (pin 36) is
strapped high (to the reset line) via jumper "k". The software doesn't care where
the RAM is physically, as long as there is RAM at page ero (it's transparent
to the software). The test program attempts to write a bit pattern to address
$0000, starting with $00 and counting upto $FF. If the test program
sucessfully manages to write and then read back (validate) the count, it then
moves onto the next byte $0001, until all 128 bytes have been checked.
256x128 = 32,768 write cycles with validation. If this is sucessfull, the LED
flashes for the *first* time (the initial flicker is not counted as a flash).
If your using a 6802 and the RAM test fails (you don't get the first flash) - you
might be lucky. Move jumper "k" (the internal RAM enable jumper) to position
"L" and install a 6810 RAM IC in U6 then run the test again, else, you'll need
to change the 680x (the internal architecture is damaged).
An interesting point here. Joel and Vickie (the Pinball Liz) listed a problem in
their tech tips #34 with the self test button on S+T not being debounced
which sometimes causes the board to crash after attempting a test.
Because the switch is not debounced, the switch contacts make and break a
number of times translating to a *number* of valid NMI requests to the 680x.
The *stack* and *workspace* RAM in S+T is only 128 bytes wide (page zero
$0000-$007F, the exact stack length is unknown to me). The 680x has to save
the contents of it's internal registers onto the stack when it encounters an
NMI (or IRQ) interrupt. A number of interrupts recieved in this manner will
cause "nesting" (interrupts are "queued" to be processed in last in first out
[LIFO] order) and the most probable cause of the board crashing is the stack
overflows, wraps around, and starts to overwrite itself wiping out the data
previously saved onto the stack. The conclusion? The uP crashes because it
pulls data off the stack that didn't match the data it originally saved.
Power-cycling is the only option to clear the problem (there is no reset button
on S+T). The problem is further agrovated by the fact that speech data
transfer requires an IRQ interrupt - further stack usage translating into IRQ
and NMI data colliding caused by the over-write when the 680x "pops" (pulls
data off) the stack.
*2nd flash*
The 680x attempts a bit-pattern write to the internal registers in the PIA at U7
(the speech control PIA) in the same manner as the RAM test. If the LED
flashes for the second time, then the test was sucessfull. If the test failed -
check the sockets/swap out the PIA.
*3rd flash*
Exactly the same test as U7 is carried out on the PIA at U11 (PSG control
PIA). A successfull test causes the LED to flash for the third time. If the test
fails, then perform diagnostics as for U7.
*4th flash*
The 680x attempts to write too the internal registers of the AY3-8912 PSG and
then read the data back using the PIA at U11 as a parallel interface. A pass
is indicated by the fourth flash of the LED. If the test fails - swap out the PIA
at U11 for another (the U11 PIA self test cannot test the input/output state of
the actual pins as there is no data "loop back" - it can only write to internal
I/O registers of the PIA, and whilst the PIA may test okay, the output
buffers may be faulty). If the fault continues swap-out the PSG and check the
sockets of both the PIA and the PSG.
*5th flash*
The 680x now attempts a 9 byte transfer of data to the TMS5200 speech IC. As
the 5200 stack is empty on power-up, it will flag an interrupt stating
"buffer/stack low" for every byte transfered until it has 9 bytes (it only flags an
interrupt if the stack becomes half empty - 8 bytes or less). The 680x writes a
single byte at a time and waits for the buffer low interrupt until it has fed all 9
bytes. On receipt of the 9th byte the 5200 asserts "Buffer low" *no more* and
does not assert any further interrupt. If this occurs, S+T assumes to IC is good
