I just replaced the top right molex connector on my Bally Flash Gordon. The original connector was intermittently dropping power. I matched the wires perfectly, but now when I go to turn the machine on, it won't leave test phase. & when I use the test points on the solenoid driver board, I get over voltage on the 12V test point and slightly under voltage on the 5V test point.
Newish boards: Solenoid Driver, MPU, Lighting Board, Rectifier.
Here is a grouping of images and a video testing to help: https://drive.google.com/drive/folders/1bbl5s_GyMItC2945aorDsB2PVUXKO-7U?usp=sharing
Machine was crashing prior to replacing this connector. Now it won't start at all. Any thoughts?
