So I got a chance to go take a look at the flash gordon pinball today.
I pulled all the fuses on the -54 recitifier and buzzed them all, they test fine. The 1 amp slo blo fuse under the playfield was popped, the guy only had a 3amp slo blo to temporarily put in. I wasn't super comfortable with it, but for a super temporary fix I figured it was fine. The coils weren't energizing anyways.
The -54 power voltages were all in range on TP1-TP5, both with J1 / J3 attached and disconnected.
All fuses on the -54 recitifier were good, one fuse clip seemed to be a bit dodgy, but I cleaned it up. TP voltages from TP1-TP5 were all in range on the MPU.
The solenoid driver board was a stern board, and DOES NOT appear to be the common stern SDU-100
It's this board, which I haven't identified yet so I don't know what the TP voltages should be:
ebay.com link: itm
The MPU board:
It seemed like it wasn't flashing at all (it may have been, more later). I removed all the connectors on the MPU, all the connectors on the SDB, and all the connectors on the Recitifer. None of the plugs seemed dodgy. At one point, it looks like some of the connectors may have been redone with IDC connectors. Some are a clearish pink instead of the solid white. No burning, signs of heat damage, or discoloration on any of the plugs. On the MPU, one or two of the header pin rows have what looks like slight tarnishing on them.
There is some battery acid damage. It looks pretty minor compared to what I've seen, but I do see corrosion in about a six inch by six inch area. What's weird is it's not "solid". Some vias appear corroded, some resistor legs... it doesn't look "horrible" but seems like it could cause trouble for sure.
Now, the pinball wasn't doing any flashes at all on the MPU. After checking everything I described above, I gently pushed on all the socketed chips... gave them a little wiggle pushing in on either side, then pushing in directly on the center. I still had my work light shining on the backbox, and after verifying my TP voltages, I shorted the adjacent legs of Q2 (LED did not appear to come on, but then again, my worklight was on and the LED is very dim when I did get it to come on). After powering up the pinball now, with the work light I was using turned off... I could see the LED flashing. Didn't appear to "flicker"... it just flashes steady as long as power is on, it will keep flashing. I tried several times, and each time the same thing, just a steady flashing of the MPU LED the entire time power is switched on.
Since I have verified all voltages are good, I think the problem is down to the MPU. Having said that, I didn't verify the test points on the solenoid driver board, but the test points on the MPU are all spot on.
Given all that, I'd love some feedback from you guys who are much more experienced than I am!
And a big thank you to those who have commented already
