I have a bally escape from the lost world. The pin plays fine and sounds fine. When you first turn it on, the displays only show a few lines, basically it looks like garbage, no complete numbers. As it warms up, the first 2 displays on left hand side start to work over time. The two on the right come on but don’t show correct numbers or anything legible. Occasionally when you turn the machine on, it will pop the fuse 3/16amp on the power supply.above the fuse says fc8a and below the fuse says fc8b. Right below 3/16 is fu8. So I’m not sure where else to check or where to go from here. The fuse 8 has been replaced. Same stuff. I don’t want spend anymore than I have to as it is not a forever pin. Any help would be appreciated.
