Hi Guys -- I just got my first game from a family friend and it is EFLW. Upon getting it to my house I noticed the upper right flipper is missing! rendering 1/3 of the game useless. The other 3 all work fine. I am a complete newbie at this, but I opened up the machine and saw that in addition to the flipper being removed, the wires were cut from the coil! Why would someone do that!?! It also look like it is missing the Return Spring and the Side Lever Assembly.
I guess my first question is, is this repairable? It looks like the wires have very little additional slack on them. If it is repairable a couple questions
1) Do I need to buy a complete Flipper Rebuild Kit?
2) Do i need to buy a new coil as well? Or should I just do it to be safe?
3) There is minimal slack available on these cut wires if I am going to re-attached. Can I buy additional wire to extend them and if so is it all just standard copper wire?
3) Finally -- Which wires do I solder to each Diode if I am going to put this back? I am very nervous i am going to short the machine and be in way over my head if I do this wrong. I tried to color code arrows to make it easier for you all to advise which wires go where. I think it should go
A) YELLOW CIRCLE WIRES to WHITE CIRCLE diode
B) Reconnect the wires in the BLUE RECTANGLE
C) ORANGE CIRCLE to PURPLE CIRCLE?
See the attached picture
I really appreciate all of your help!
