Quoted from Quench:So one side of the L2 inductor has 5.27 volts, the other side at the 5V test point has 5.0 volts. That's 0.27 volts differential.
I checked one of my machines earlier across that inductor and I get 0.008 volts across it which is negligible and what I expect.
Can you measure the voltage across that L2 inductor (put the red meter lead on the left leg and black meter lead on the right leg) to confirm the voltage drop across it?
Does that inductor get warm/hot to touch? Seems like something is loading down your 5V supply at the MPU board which is possibly making it unstable and causing the CPU to crash.
Can you report the other voltages on the MPU board test points?
Sorry for the delay, was at the York show.
Here's the voltage tests:
L2 5.27 V on left side, 5.0 V at test point.
Voltage drop across it (red left, black right) 0.00 to 0.001 L1 does not get warm
L1 13.83 left, 13.70 right
R113 44V left, 21.8 right
These were the only voltage tests on the Callahan board.
