Trying to bring a Bally Eight Ball back to life. I cannot get the outhole solenoid to fire and return the ball to the plunger. However, I did a quick short of the solenoid to ground and the solenoid fired just fine. 43v on the yellow wire and proof of a good solenoid lead me to believe it is either the switch or the transistor. I followed the brown with yellow wire back to J1, Pin 5 on the solenoid board and did a quick resistance check on transistor Q4. It is not shorted to ground, so not blowing fuses, but maybe that circuit is my problem? Is there a way to test the transistor Q4 circuit without removing connections on the solenoid board? I hate doing that only to find out it was something else. For example, the switch for the outhole kicker is part of the switch matrix. When I close the switch, with the game on, other items on the board fire, which leads me to believe the switch is making contact fine. Before I go tearing into the transistor circuit, is there anything else I should be checking? That 43v is too high to use a logic probe on the circuit so I'm not sure how to check it.
I am having the identical problem with the side kickback solenoid. Fires fine when shorted and transistor shows resistance. Harder to diagnose this one since it does not fire all the time when the switch is closed.
I have two other solenoids not working (bottom bumper and extra chime) but I have tracked those back to transistors showing zero resistance so I know I have to replace those transistors or something in those circuits.
Would appreciate any guidance.
