(Topic ID: 238902)
Bally Eight Ball Acting Odd
By SilverballSleuth
2 years ago
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by wayout440
#1 2 years ago
Alright. So, I picked up a Bally Eight Ball a few weeks back. When I bought it, I was told the MPU was flaky (the board looks HIDEOUS) and that I had the option to buy the game with an Alltek. I declined to buy the Alltek. Three weeks later, game went crazy. Some light sockets refused to turn on, a little later, a chime coil stopped working. Did a power cycle - coils started locking on. Game stayed off, Alltek MPU ordered. Even if that's not the issue here - I should have an Ultimate MPU regardless.
Followed the install instructions exactly, checked for 5 on TP1, came in exactly at 5.25 - on the highest acceptable number, but in acceptable range.
Put in the Alltek, the game did indeed start up, but coils still acting odd, bulbs as well.
What's the next troubleshooting step here? Solenoid Driver? I really appreciate any help.
Thanks,
Eric
#2 2 years ago
Quoted from SilverballSleuth:
Thanks,
Eric
5.25, I assume volts DC? Measure the AC ripple there to check power supply caps. (This is not likely the cause of your problem, because usually a problem with the logic power will cause random or no boot up, and not cause the game to "go crazy")
Any signs of current or former corrosion around the battery area? This can spread like a disease when poor attempts have been made to clean.
Coils locking on random and other crazy usually points to logic problems, and if the boards have been worked on by someone inexperienced it would have to be gone through with a fine tooth comb. There could be wrong parts, solder shorts, trace damage - you name it. These games are also notorious for needing a LOT of repinning on the header pins and connectors. Go through the service docs for each board one at a time, performing any needed repairs and upgrades (there are a few for this series on each board), repin where necessary and then revisit the situation for advanced troubleshooting.
http://techniek.flipperwinkel.nl/ballyss/rep/index1.htm
#3 2 years ago
Power is OK and you have the Altech installed.
Reflow the pin headers on the solenoid driver and lamp boards. That's where I would start.
#4 2 years ago
Quoted from wayout440:
Really appreciate this info. Gonna check the AC (I should have to begin with, will do it tonight or tomorrow morning.) That very well could be my issue. There are times the game won’t start up.
#5 2 years ago
If the power supply doesn't reveal a problem, pay close attention to the cables delivering logic power to the CPU. The connectors need a gas tight fit to deliver good current. Repinning the connects helps a lot. Http://www.pinrepir.com/connect/
#6 2 years ago
OK...I'll probably get thrashed for saying this....It's an early Bally....if you are flipping it you can stop reading here...If you intend to keep it, then both Pins and the cables that plug onto them need to be replaced/rebuilt with new on the Solenoid driver board, the MPU and total rebuild the power supply. I've done this to every early Bally SS I've owned. I guess, to me, it's sort of like the Williams System 3-7 where you can't really even begin to trouble shoot until you rebuild the 40 pin inter-board connecter...I feel the same way about the early Ballys… new pins and plugs otherwise you will just keep chasing problems.
#7 2 years ago
Okay guys, I measured the AC - it bounced around a lot and then settled at 10.5. It should be at 15, right?
Got it to boot a game today, lights were strobing, (300 bank shot, then 600 bank shot, etc.) plus a few random pool balls were on.
With this new info, is it the solenoid driver board? Or is it the pins more likely?
Whatever I have to do, I'll do, I love this game and would like to keep it for a very long time.
This is my first Bally SS, sorry for my lack of knowledge here.
Thanks again everyone,
Eric
#8 2 years ago
Not sure what you are measuring. AC ripple on the +5VDC logic voltage should be in millivolts (mV) - well under a volt. When dealing with electronics you really need to specify the units of measure.
#9 2 years ago
wayout440 - I greatly apologize. I’m not trying to be difficult, I’m just clueless here. I’m going to do some research, buy a real meter tonight (mine is a Wal-Mart one from many years ago that my dad had) and check it again tonight - I’ll give you a real number and a unit of measurement when I post here again.
I appreciate your patience and expertise. Thank you so much.
#10 2 years ago
No need to apologise. Measuring AC ripple is just a check for the quality of your DC power. When you post meaaurements without a unit of measure it makes it difficult for us to interpret what is going on and give correct advice.
#11 2 years ago
It lives!
With my new meter I came in at:
5.26V DC
38mV AC
After that, I decided to follow the advice of looking at connectors. Took out the solenoid board, and the solder didn’t look the best. Reflowed and BINGO! She came to life.
Thanks to all for your help - I’ll have a better idea what to do next time.
#12 2 years ago
5.26V DC
38mV AC
btw...The numbers are spot-on. You have a healthy power supply Glad you got it running!
