I have a Bally EBD, and up until yesterday everything worked fine. No power now at the Right flipper. Both left flippers work correctly, and show 43 volts at the coil when the button is pressed. Absolutely nothing on the right flipper.
I checked EOS switches, they are closed and there is continuity to the coil lugs.
I checked the diodes, there is continuity through each diode.
I understand this power comes off the fuse and goes directly to all 3 flippers with a common wire.
Anything I'm missing? The coil looks fine, no broken wires,.. even if the coil was bad there should still be power at the coil?
I cleaned all EOS and cabinet switches, and checked continuity.
No problems.
What am I missing?
