I've been tired of Bally drops bricking for years. Decided to tackle this after finishing my Mystic playfield swap, because the center bank especially and the side banks to a lesser extent just wouldn't drop. I figured I'd swap a classic stern drop in - nope, too many changes (unless I swapped the entire bank). Tried to shave the bally 'shelf' on the drop to more of a 'stem' like stern has.... nope.
While mixing and matching stern parts, I noticed that there is a slight bend upward on the stern drop retainer, so that the drop has to go up a slight bit instead of going back directly. I wondered if this is why the stern drops are really smooth. Since I have extra bally banks, I put a small bend in the top plate to make it a hump shape (see pics and video). This works. (See middle of video with direct hits from flippers onto the drop bank).
Maybe it works better because of the less surface area on the bent part, or maybe it's because of the slight upward bulge. The drops are not noticeably higher up (it's a very small bend). Is it a hack? Maybe. Is it better than hitting a bricked target and the ball draining? IMO, yep.
It's still not going to drop a target on the sides when you hit the *side* of the drop, but I wouldn't call that bricking.
