Hi all, I have a Bally Dolly Parton that has a dead right flipper, the left is working just fine. The solenoid driver board just had a bunch of work done by a professional, the solder points on the flipper coil are solid and the solder points on the switches are also good. I checked the switches on the flipper button, cleaned the contact points and they look good. I don't have any burned out fuses. What should I try next?
