a most troublesome bally 6 digit display that has an issue with the one's digit being stuck on (none of the other digits will display and the one's digit is a bit abnormally bright as one would expect)
I replaced both Q1 & Q7 with new and have same result - one's digit still stuck on, checked the associated resistors and they are within spec/tolerance, so i changed the MPS42 and 2n5401 again, still no love same results
I pulled Q7 and the 5 other digits work just fine with the one's taken out of the picture
am i missing something here or is the display failing internally? am leaning towards a failing display
