I have a Bally Cybernaut with multiple issues. Originally the Cheap Squeak sound board had a burnt tantalum at c10. I replaced c10 and all of the electrolytic capacitors, and now the led blinks 3 times, and stays on on the forth. I have sound when I push the test switch on the sound board, but not in game play. Also after I replaced the capacitors the mpu would not boot with the sound board plugged in, but it would without the sound board connected. Now for some reason in does power up when connected. The other problem is that the flippers will cause the mpu to reset. I have installed 2 new coils, and any of the flipper coils will cause the reset. The mpu is a 6802, with voltages as follows;
Tp1=5.2
Tp2=15.7
Tp3=44.5
Tp5=5.2
Tp6=13.6
I noticed that R4 a 2k resistor is burnt, but still reads 2k, and in the notes on the schematics states that the board should either have R4, or D1. This board has both.
I tried a older Bally mpu to check the flippers, and had no resets. I also took the 6802 mpu, and put in a different game, and also had no resets. I also put a different solenoid driver board that has been rebuilt with no change.
Any help would be appreciated.
