Having issue when trying to add player. Coil is good and when I gator clip it works. Im confused why credit button switch is not in the path to engage player unit step up coil. Also confused with Outhole relay switch that is normally open in the path. Outhole coil has 2 paths: one with Outhole switch path which is fine but the other one with scm 8c plus a normally open switch in the Outhole relay stack up? It has to engage itself to engage itself to complete that path?
I also trying adding coin after start up routine and nothing.
