(Topic ID: 218048)
Bally Centaur Flipper sticks
By SomeCaliGuy
5 years ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 5 years ago by BigAl56
#1 5 years ago
I have a Bally Centaur and the left flipper will stick up during game play after hitting the ball. It seems hitting the right flipper will help it fall back down. Here's a video. I'm not sure if lubrication can fix it or if there is another reason for this issue.
#2 5 years ago
Make sure your cabinet switch isn't staying closed after you let go of the button. If not, check return spring, and remove clean and replace coil sleeve, flipper bushing, and coil stop, ah hell, just clean and rebuild that whole assembly.
Had a magnetized coil stop not to long ago.
#3 5 years ago
Don't lubricate, they're designed to run dry.
#4 5 years ago
Other thing is make sure your flipper plunger is lined up with (parallel to) the coil. If you angle it up to much (tightening it onto the flipper shaft too high) or to low, then you can get some binding especially after playing a while.
However, if you haven't rebuilt the flippers yet, go ahead and do that and make sure the plunger is lined up with the coil when you put it all back together.
#5 5 years ago
Quoted from SomeCaliGuy:
I have the same issue with my upper right flipper on my D&D machine, I rebuilt the flippers and the strength is back, but it does on stick up sometimes. I found that the plunger doesn't always come all the way out of the coil. When i built the flippers i didn't change the coil and that is where this problem is in my case. If you can replace your coil and sleeve and i bet the issue will go away. I use machine lubricant on it for now and it works but eventually it dries up and need to add more (yes i know you shouldn't, but the coil is already in need of replacement), but will be replacing the coil at some point.
#6 5 years ago
SilverballNut thanks for the response. I was thinking it was something like you were describing, but I couldn't articulate it very well. When I lift the playfield there did not seem to be any resistance, but when it was back down it would like there was some kind of friction. I took OCD_pinball advice and removed the coil stop and I cleaned the sleeve with alcohol. It did not seem excessively dirty and the coil sleeve moved freely. Perhaps when I put everything back together the alignment became correct? Maybe it was a combination of the two. I immediately noticed a difference afterward and I played 5 balls on the machine and not once did it stick. Thank you guys so much for the advice.
#7 5 years ago
silverballnut thanks for the response. I was thinking it was something like you were describing, but I couldn't articulate it very well. When I lift the playfield there did not seem to be any resistance, but when it was back down it would like there was some kind of friction. I took ocd_pinball advice and removed the coil stop and I cleaned the sleeve with alcohol. It did not seem excessively dirty and the coil sleeve moved freely. Perhaps when I put everything back together the alignment became correct? Maybe it was a combination of the two. I immediately noticed a difference afterward and I played 5 balls on the machine and not once did it stick. Thank you guys so much for the advice.
Well let's hope that is the fix, mine would work fine for days and then start sticking on the up stroke again. And the coil sleeve wouldn't come out of the coil so that's how I know I need to replace my coil.
#8 5 years ago
Sounds like a pounded plunger
#9 5 years ago
Are both springs the same strength?
snaroff
#10 5 years ago
Heres a simple check, swap the coil stops with the other working flipper. If the problem moves with the coil stop you need to replace it. I would order a rebuild kit no matter what.
$ 69.00
Pinball Pimp
5,990
Zemst
6,195 (OBO)
West Chicago, IL
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 18.95
Retro Electro Designs
$ 69.00
Pinball Pimp
$ 33.95
Metal-Mods
$ 17.50
$ 22.50
£ 195.00
Metal-Mods
5,900 (OBO)
Worcester, MA
This page was printed from https://pinside.com/pinball/forum/topic/bally-centaur-flipper-sticks and we tried optimising it for printing. Some page elements may have been deliberately hidden.
