Hi David
great, You found it. A couple of things to know about EM pins and schematics:
Bally and Williams are very similar - Gottlieb is different, "Score-Motor" and especially: The way "Balls" and "Players" are handled - (Gtb: ) "Player-Unit <-> (Bally, Wms: ) Ball-Count-Unit and Player-Unit.
Pinball machines and schemas are "Man made" - a (specific) switch is IN THE PIN "Normally-Closed" - by mistake it is drawn (in the schema) as "Normally-Open". I once read ( do not remember where): "Carefully checked schema and "reality in the pin", result: Two switches drawn in the schema were NOT in the pin - one switch in the pin was NOT drawn in the schema.
Schemas are not an "exploded (explosion) view" - they show a momentary state (snapshot). Some schemas (only) have the note "Interlock-Relays are drawn in latched position". Some have a better description (I assume: ALL EM-pins (schemas) are drawn) -
"The schema shows: A game has been startet for one player, the machine made the "Reset", the first ball is transported (Outhole -> to the "Launching Lane" (ready to get playing) - AND NOW - after all this: The Line-Cord (110 VAC) is PULLED / unpugged !!! (and therefore Interlock-Relays are in latched position).
A schema does not show the reality of "wiring in the pin" - a schema is an "abstract". In a schema You often see a "connecting point (5 wires end here)" - in reality there is a wire A <-> B, a wire B <-> C, a wire B <-> D and a blank (no insulation) stump C <-> E.
Relays (coils) (K, L, M, N) drawn side by side (from left to right) in the schema: Reality: N and L are in the Backbox, M is in the Cabinet, K is at "Underneath-side of playfield".
Jones-Plugs for (example) connecting playfield and Mech.-Panel (in the cabinet) are usually NOT drawn in the schema.
Succession / sequence / chronology: YOU must think it into the schema !!! An example "10 points are given ("B1-B6")", "Reset of a Score-Reel ("A1-A8")" -> https://pinside.com/pinball/forum/topic/scoring-issue-on-bally-sea-ray -> post-4, PDF-A-B. ((PDF-C-K is in search for a "STUCK 100 Point-Relay))
When reading a schema I often see switches "I do not really understand what they are (good) for ...". I keep in mind: The previous game might have ended nicely (played until Game-Over) - OR A PLAYER HAS BEATEN THE MACHINE AND PRODUCED A SEVERE TILT, for example look here http://www.ipdb.org/showpic.pl?id=2539&picno=10658 -> Player-2 (of 4), Ball-2, Ball sits in one of these Eject-Holes -> BANG, severe Tilt. Or an Service-Man has taken-out the ball, lifted the playfield and want to start a game ...
"Switches I do not really understand ..." often have to do with "strange circumstances of End-of-previous-game".
When I see a switch "drawn Normally-Closed in the schema" - but I would like to have it "drawn Normally-Opened" -> I locate the Relay and the (attached) switch in the pin -> manually activate the relay and look: Does the switch wants to open ? - or: Does it want to close ...
For "to work on a pin" I really like Williams, example Fan-Tas-Tic: http://www.ipdb.org/machine.cgi?id=820 (example: ) I have problems with a switch on "Outhole-Relay" -> http://mirror2.ipdb.org/files/820/Williams_1972_Fan_Tas_Tic_Operator_Manual.pdf -> page-21 -> where is the switch ? / how many switches ? what are they doing ? where in the schema is a specific switch to be found ? how is the relay energized ?
I Like "Williams of the 70ies", Gottliebs (at least) have in the list of relays (in the schema) notes like: 4A, 2B, 1C -> this relay has 4 "Normally-Open" switches, 2 "Normally-Closed" Switches, 1 "Make-and-Brake" Switch.
Gtb / Bally: I often have to look all over the schema to find the switches a specific relay does move ...
I also like "Wms-drawing (schema) - the Score-Motor": the "Notches / Cams", the "Timing", "Switches involved" - "what are they for".
Looking for a fault:
here we had "using stripes of paper to insulate connecting points in a given switch" (current flows where there should no current flow).
Often the problem is "the other way": "current should flow, why doesn't it ?" For this question I like to use "Jumper-Cables with Gator-Clips". A SCHEMA IS NEEDED !!!
Look: https://pinside.com/pinball/forum/topic/using-schematics-and-8-foot-jumper-wires -> post-6, post-7, (post-10). I do not like "Continuity-Tester" - in an EM-Pin: there are so many connections - You may get results measuring "all the way around through the wiring of the transformer". Sometimes I use my "green flashlight" but mostly I study the schema and the pin / use paper-stripes for insulating and Jumper-Cables to make connections.
David, please mark the topic as "solved". Greetings Rolf
P.S.: Great: http://www.pinrepair.com/em/index.htm / http://www.pinwiki.com/wiki/index.php?title=EM_Repair
