Dear Forum,
I have a problem with the Close-Flipper-Solenoid (E-184-239) of my Bally Capersville.
The measured resistance is 1.9 Ohm.
I think it is broken due to a EOS problem, ignored by the previous owner.
When the red mushroom bumper (which should close the zipper flippers) is lifted, the bats make a very short nervous twitch of about 1 millimeter and then the 1.6 SB fuse blows.
Since the coil is riveted etc., I am not sure if it can be disassembled for rewinding.
The problem is that I can not find a spare part for 50 Volts, only an equivalent type for 24 Volts.
Is it possible to use the 24 Volt solenoid with a series resistor ... or two 24Volt solenoids in series?
Thank you
