(Topic ID: 190127)
Bally Bowl-O Project
By troxel
6 years ago
  • 32 posts
  • 7 Pinsiders participating
  • Latest reply 5 years ago by troxel
#1 6 years ago
Got a Bally Bowl-O and started going through it. It's in pretty rough shape, but up for the challenge. Thought I would start a thread on the process of it and have a venue to ask questions when they arise. Hope to learn a few things on the way.
#2 6 years ago
Thing I did yesterday:
**Father-in-Law reattached the base board on the head. Came undone and he glued and re-braced it.
**Cleaned and vacuumed the base of the machine
**Replaced power cord
**Replaced four fuse blocks and soldered broken wire on the power transformer
**Half way done rewiring the coin door. Mouse chewed on a number of wires in the front of the game.
Next items to work on:
**Finish wiring coin door
**Get 4 bolts to mount the head
**Rewire the other front wires (flippers, knocker, tilt, etc)
**Try to find a backglass (might be a hand drawn 5 year old picture if I can't find one)
#3 6 years ago
Thats a cool old machine,I wouldn't have walked away from it. A full size paper print behind a glass looks ok if you can get a picture of the original.
Odd ball machines you don't see everyday bring back old memories of an Arcade/Pool Hall in Belhaven NC.
#4 6 years ago
Thing I did today:
**Finished rewiring the coin door, knocker, and power switch.
**Found 4 bolts for the head
**Put the bottom panel back in the game and connected the front jones plugs. I have a stray jones plug that has one connection on both
and not sure where it goes. I will try and look at the adjustments tomorrow for the missing jumper.
**Checked coils on the playfield and all moved freely and none were burnt looking.
**Moved one of the stepper units on the playfield and moved freely and snapped back in reset position. I was shocked that it wasn't gummed up.
**Reassemble rest of the game and give everything a look over.
**Try to find a backglass.
Quoted from phil-lee:Thats a cool old machine,I wouldn't have walked away from it. A full size paper print behind a glass looks ok if you can get a picture of the original.
I like the large photo idea. That's probably the route I will go.
#5 6 years ago
**Wiped down right side of game
**Put the head on along with the pf
**Found another mouse's nest
**Cleaned and adjusted the score reels.
**Disassembled Replay Unit
**Finish cleaning/adjusting the rest of the units in the backbox.
Down the road items:
Photo Jun 01, 1 11 18 PM (resized).jpgPhoto Jun 01, 1 11 18 PM (resized).jpg
Photo Jun 01, 3 33 33 PM (resized).jpgPhoto Jun 01, 3 33 33 PM (resized).jpg
Photo Jun 01, 4 46 39 PM (resized).jpgPhoto Jun 01, 4 46 39 PM (resized).jpg
Photo Jun 01, 4 32 55 PM (resized).jpgPhoto Jun 01, 4 32 55 PM (resized).jpg
#6 6 years ago
Things I did yesterday:
**Finish going through Replay Unit, Ball Count Unit and the 0-9 Match Unit. Replay unit was really misaligned. Would only move one step before hitting a switch and being stuck.
**Clean jones plugs
**Dust of the fire extinguisher
**Plug in game and see what happens
**Order rubber kit, schematics, manual (if available)
Photo Jun 02, 5 33 11 PM (resized).jpgPhoto Jun 02, 5 33 11 PM (resized).jpg
Photo Jun 03, 9 46 48 AM (resized).jpgPhoto Jun 03, 9 46 48 AM (resized).jpg
Photo Jun 02, 8 49 11 PM (resized).jpgPhoto Jun 02, 8 49 11 PM (resized).jpg
Photo Jun 03, 10 01 47 AM (resized).jpgPhoto Jun 03, 10 01 47 AM (resized).jpg
Photo Jun 01, 1 12 18 PM (resized).jpgPhoto Jun 01, 1 12 18 PM (resized).jpg
#7 6 years ago
Any idea what these jones plugs are for? Every other adjustment had a label to figure it out, but these two didn't.
Photo Jun 03, 10 01 30 AM (resized).jpgPhoto Jun 03, 10 01 30 AM (resized).jpg
#8 6 years ago
Those look to be adjustments for replays if you get enough points or bowling strikes. Here's one relevant part of the schematic.
#9 6 years ago
Quoted from HowardR:
Makes sense. Thank you for the help.
#10 6 years ago
This is the part of the restoration where I will need some help .
Finally turned the game on this afternoon and the score motor just spun. Looked at the schematics and checked the following relays:
I focused on the switches with the red-yellow wire and all looked good. The 1A scm had the two tabs touching and adjusted that. The score motor now stops spinning. I can coin up a game and the credit unit advances, but nothing happens when I hit the start button. The reset relay and hold relay are both energized. (If the reset relay is engaged, shouldn't the score motor be spinning?)
Not sure where to look next on the start up sequence. Any suggestions would be much appreciated.
#11 6 years ago
The Reset relay switch in the schematic you attached is probably out of adjustment. If not, try jumpering from the Yellow wire on the transformer to the yellow wire on that switch. Then to the Red&Yellow wire on that switch.
#12 6 years ago
I adjusted that switch and now the score motor is spinning continuously. I manually set each score reel to zero and checked contacts. I just don't know what should be engaged and what shouldn't be. So far the reset re is locked on along with the hold relay.
#13 6 years ago
Check these switches in the circuit for the Reset relay.
#14 6 years ago
Thanks for the help, HowardR!
Switch 1B SCM was closed and adjusted it. Now the reset relay unlatches and the score motor stops spinning. I can add credits and show up on the credit window, but when I hit start, nothing happens. I imagine that I need to look at the start relay circuit? Or, is it the coin relay circuit that I need to look at?
#15 6 years ago
Check the circuit that includes the replay button switch. This would be the circuit that sends power to the start trip relay coil.
#16 6 years ago
Thanks for the suggestion, fredsmythson. Totally makes sense.
My guess is the path would look like this?
My question on this is where is the #2 Reset Motor located at?
#17 6 years ago
Looks like 3 motors on the right side of the bottom panel. Are they labelled?
#18 6 years ago
Looks like #2 reset motor is below the start and #1 reset motor is above the clutch. Niether were labeled.
The game over and start relay are both latched and nothing else happens. Looking at the start sequence on the pinwiki, just not sure what step I am on.
#19 6 years ago
Quoted from troxel:
Quoted from troxel:
You're on the step where the Start Trip relay should activate.
#20 6 years ago
Ordered the schematics today and will post questions when they arrive. See if a better copy will help.
#21 6 years ago
Quoted from troxel:
I've a very similar non-labelled adjustments bank on my Bally Rocket III for setting hi-scores - it turns out that the settings were on a large chart taped to the inside backbox cover long since fallen off & lost. Perhaps this machine had similar originally.
#22 6 years ago
Got the manual and schematics and now have some questions on it. I believe I am on the 2nd step of the start up sequence. I am not getting any response when the replay button is pushed.
I imagine the "game over trip relay" should be closed on the start trip relay circuit.
InkedPhoto Jun 11, 3 37 16 PM_LI (resized).jpgInkedPhoto Jun 11, 3 37 16 PM_LI (resized).jpg
What is the best way to inspect this switch. I realize there is a wing nut to remove the stack, and I can move it about a foot, but doesn't seem like enough to investigate. I have a been putting it back in place and struggle to get it lined up correctly. Is there a trick or something I am missing?
InkedPhoto Jun 11, 3 37 40 PM_LI (resized).jpgInkedPhoto Jun 11, 3 37 40 PM_LI (resized).jpg
#23 6 years ago
After some adjusting and tweaking, I am able to start a game! All scores reset and ball count goes to 1. However, the 1000 relay locks on and won't turn off. It looks like the top path is completing the circuit. The top center lane relay is showing closed on my DMM even though the switch is open. I checked the tabs and they aren't touching. Also, the actual switch on the center roll over is open so the top center relay is not engaged. Am I missing something else?
#24 6 years ago
Fixed the 1000 unit problem and now have 100 unit problem. There was a roll-over switch that was closed that shouldn't have been. Didn't realize at first that the roll-over was worth 1000.
Two problems with the 100 point unit:
1. The 100 unit the relay is locking on after 100 points is scored. If I open the EOS switch the relay shuts off. When I manually score 100 points sometimes the coil engages and other times it doesn't. Sometimes it is really weak pull on the coil. Is this an adjustment or possible bad solder joint on the coil? I ohmed out the coil and was same as the 10s and all switches on the unit are good.
2. 100s is it is not advancing when the 10s unit goes from 9 to 0. I check all switches on the 10s unit and are good.
Any advice on what to double check? Kind of talking out loud here, but would appreciate any help.
***Looks like it was just a dirty contact. 100s are now working fine. I will go through and see if all switches are registering next and then will probably clean the PF***.
#25 6 years ago
Looks like all the switches are scoring including the pops. What is the best way to clean and adjust these switches? I tried moving the wing nut and moving the whole unit out, but still don't have much room. Do you remove the rectangular plastic piece that holds the individual relay switches in place? Or, is there another method?
**Just found this on Youtube. Looks easy enough.**
#26 6 years ago
Just last weekend I inherited this game from my inlaws. It's been in their basement since the late 70s. I found your thread as I'm researching how to go about cleaning it up. You mentioned getting a manual and schematics. Can you tell me where you ordered them from? This will be my first attempt at repairing a pinball machine, and I'll need all the help I can get.
#27 6 years ago
http://mirror2.ipdb.org/files/368/Bowl_o_Sch.PDF
Also, Marcos and Pinball Resource have a lot of schematics for sale
#28 6 years ago
I got mine from Pinball Resource (http://www.pbresource.com/). Order the manual, schematic, and ring kit from Steve. I struggled reading the online schematic as it's not the best copy, and I like having a paper copy.
Went through and cleaned the playfield today and got majority of it put back together. I try and get a few photos tomorrow when it's done. Game was playing fine, but didn't check things like replay and strikes yet. This has been a fun project and learned a lot on it and hopefully getting close to done.
BowlO I'm jealous of your backglass. Makes the game look a lot better than looking at burnt out lights.
#29 6 years ago
It's getting closer. I put it back together and even rounded off the shooter's rod. The only problem that I am having is the strike lights are not lighting. The strike unit is advancing, but no lights. Will investigate some more when I have time. Played a few games and the scoring, lights, and switches all worked.
Photo Jun 17, 5 28 38 PM (resized).jpgPhoto Jun 17, 5 28 38 PM (resized).jpg
Photo Jun 17, 5 28 32 PM (resized).jpgPhoto Jun 17, 5 28 32 PM (resized).jpg
Photo Jun 17, 5 15 05 PM (resized).jpgPhoto Jun 17, 5 15 05 PM (resized).jpg
Photo Jun 17, 5 28 35 PM (resized).jpgPhoto Jun 17, 5 28 35 PM (resized).jpg
Photo Jun 17, 5 28 07 PM (resized).jpgPhoto Jun 17, 5 28 07 PM (resized).jpg
Photo Jun 17, 5 00 53 PM (resized).jpgPhoto Jun 17, 5 00 53 PM (resized).jpg
#30 6 years ago
If you're talking about the 10 strike lights just above the flippers, they're controlled by the Strike Unit. Is that unit working? Is its disk clean?
2 months later
#31 6 years ago
Hi Troxel, First of all: Wow you did a great job with your Pinball!
As a hobby i redraw schematics from pinball machines, so they a readable again. as a goal i redraw them in the wire colors.
Maybe you can help me out with your Bowl-O.
I'm missing a part of the schematics i attached.
Can you please make a picture of the missing part?
1 year later
#32 5 years ago
Just following up on this post. I did get the schematics to Michael in the above post.
A friend of mine redid the backglass on a print. It's not perfect, but way better than anything I can do. I am going to bring this to TPF tomororow. Any EM pros that can lend a hand with it if there are problems?
$ 3.00
This page was printed from https://pinside.com/pinball/forum/topic/bally-bowl-o-project and we tried optimising it for printing. Some page elements may have been deliberately hidden.
