My Bally Boomerang has developed a puzzling issue.
When 100,000 points are scored, a light should illuminate behind the backglass, showing the player has reached that level.
While the lights worked in the recent past, they will not light now without manually engaging the coil in the back. This is the same for all 4 players. The bulbs are good. Everything else on the pin works well - no other symptoms.
What triggers these coils to close and illuminate the 100,000 light? Easy fix, or ???
Many thanks!
Bannister
