(Topic ID: 271127)
Bally Boomerang playfield lights issue
By daanguillaume
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by dgAmpGuy
#1 3 years ago
Hi again ,
I have a bally boomerang that works 100% except for the playfield lighting . The lights in the head are working fine .
Checked the circuit and the fuses , lock relays is working and contacts are clean .
Checked and cleaned the connectors so I'm currently stuck.
20200617_174441.jpg20200617_174441.jpg20200617_174402.jpg20200617_174402.jpg20200617_174304.jpg20200617_174304.jpg20200617_174357.jpg20200617_174357.jpg20200617_174254.jpg20200617_174254.jpg
#2 3 years ago
Power needs to travel through the following path to get the playfield lights to work:
Fuse block / 15 amp fuse - yellow/brown wire and blue/red wire
Lock relay switch - blue/red wire and blue wire
Playfield Jones plug - blue wire
Check if the fuse in the fuse block is tight. Check the switch and plug again to make sure they are clean. Plug should be seated tightly. Check if there is 6 volt power at the fuse block, the lock relay switch and the Jones plug.
If all of these check out okay, then there is a break in the circuit leading to the playfield lights.
#3 3 years ago
Quoted from fredsmythson:
If I measure on the fuse block I get around 40 volts on that wire .
Lights aren't burnt out
#4 3 years ago
Quoted from daanguillaume:
You should not get 40 volts in a GI circuit. That's a 6v circuit.
#5 3 years ago
If you really have 40v on a light socket then you must have a short somewhere to the coil voltage and your bulbs are going to be all burned out. I would double check at a socket and pull a bulb out to test it for continuity.
Dave
The Pinball Scientist
This page was printed from https://pinside.com/pinball/forum/topic/bally-boomerang-playfield-lights-issue- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
