Alright,
I haven't had much time to work on this machine but finally got around to it... I noticed that not only are the flippers too strong, but pretty much every solenoid is. The [insert real name of the two triangle things on either side of the flippers - I'm drawing a blank, too much inhaled lead fumes] sometimes kick the ball up in the air, as do the pop bumpers.
Lights go dim in the room each time I hit the flippers - they do too with the Surf Champ next to it, but much less.
I checked the test points on the solenoid driver board and TP5 gives me 14V when I should get 12V +- 1.4V, and TP4 260 when it should be having 230 +-27.4V. Everything else is within the ranges.
I'm not sure I understand how this goes. Isn't the flipper coil voltage supposed to be 43V? If so where should I check it?
