Am trying to repair a Black Pyramid. The owner said it would reset, machine gun right slingshot and scoring would run up.
I have it at my place, adjusted leaf switch on sling and that seems to have sorted it out, however occaisionally scoring still runs up - it appears to be related to the pop bumpers and leaf switches either side of the pops, but i cant confirm that with testing i've done to date. In switch test, there are no stuck switches, and when i thump the playfield in switch test nothing actuates (however i think on these machines, switches in switch test need to be pressed for a second or so?).
The other issue is seemingly random resets, and adding of players. I would start a 1 player game, then part way through it would change to 4 player - i couldn't pick up when this happened - and the start button leaf switch is gapped properly, and doesn't get physically stuck. Also, on some games when it stayed in single player, it would completely reset, or sometimes get stuck on a score and light sequence - everything was frozen (scores and insert lights), until i hit start button again.
This happened with the original mpu, which looks a bit nasty with some corrosion, so i put a brand new NVRAM Weebly board in there, and it is still resetting and displaying all of the above behaviour. I tested the 5V on the MPU, and managed to get it on a reset when the ball drained as player 1 - the votlage appeared to stay a solid 5.2V the whole time.
I've reseated plugs on the solenoid driver board and power supply board, really have no idea where to go here. Could be a wiring issue?
