(Topic ID: 257651)
Bally Black Jack Solonoid driver
By Geertsen
#1 4 years ago
Hello, my right flipper stopped working, so i went to the solonoid driver board J2 and wiggled the connector. I saw a flash of light behind the board. I took the board out of the machine and I spot this. The solder is burned off. My question is, can I resolder the pin onto the board? Cheers
#2 4 years ago
That is the pin for the right flipper. I would just reflow the connectors on the board, should be okay. If that one had a bad solder joint others are probably cracked too.
#3 4 years ago
Be sure to reflow the solder for all pins on the electro-mechanical relay on the board as well.
#4 4 years ago
Reflow ALL the printheaders on the board!
In your picture the first one on the left and the three on the right are all cracked.
While you have the board out, replace the big capacitors.
Do the ground upgrade and reflow the solder on all printheaders.
Do some reading on pinwiki if you want to know more.
https://www.pinwiki.com/wiki/index.php?title=Bally/Stern
Peter
Troxel Repair
$ 18.95
$ 99.00
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
$ 69.00
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/bally-black-jack-solonoid-driver and we tried optimising it for printing. Some page elements may have been deliberately hidden.
