Hi,
After fixing a shutter panel issue (not closing after 1st ball enters playfield), readjusting sw #2a ball lift motor and ball gate switch, the shutter panel now closes. I think I now have another issue, concerning the Timer Unit.
The Timer Unit manually advances and resets snappy.
The Timer Unit does advance 1 step each time a ball is shot and entered the playfield.
After the 5th ball is shot, the Timer Unit advances and also advances a few more steps (not sure how many) but the motors stop running. Which I think is a good thing so it does not burn up.
I thought if the game was left idling (whirling/clinking/clacking) for a while it will then, I will say time-out and shut the motors down.
It only times-out after the 5th ball was shot.
If I press the yellow button for an extra ball, the Timer Unit advances every-so-often and it will eventually time-out with or without giving an extra ball.
Any thoughts/suggestion?
Thank You
Steve
