New! Dark mode!
(Topic ID: 277633)
Bally Backglass Clear Coat or not
By fast70
32 days ago
  • 8 posts
  • 7 Pinsiders participating
  • Latest reply 31 days ago by ForceFlow
    #1 32 days ago
    I have a Bally black jack pinball in good shape was wounding about clear coating the back glass. it is original very good condition. bright and vibrant on the colors. very very little flaking. no touch-up attempted. clear coat. or not???????
    #2 32 days ago
    The advice I wish someone told me when I tried this...
    “Leave it be”
    #4 32 days ago
    it has lasted this long, why risk it?
    #5 32 days ago
    I never do anything to a backglass that is intact. If it's fine, I leave it alone.
    Using triple thick to seal the paint is to arrest the paint loss that is in progress since it will only get worse as time goes on.
    If there are only a few small flakes missing, it's a judgement call as to whether or not it looks like it will get worse. If it looks like the flaking may spread, then a small spot repair might be prudent.
    However, as long as you keep an intact backglass in a temperature and humidity controlled environment and get rid of the incandescent bulbs (to reduce heat), it should remain intact.
    #6 31 days ago
    Spot clear only if you have lifting and as stated above think it’s going to spread. Temp and humidity can wreck a backglass. A friend did a Bally Star Trek on a hot humid day and the graphics peeled off in mass. There are many stories just like his.
    #7 31 days ago
    Quoted from Nhpolarbear:
    Yep. I've sealed many back glasses and then did one on a humid day and I started getting messed up graphics as well. Proceed with caution.
    #8 31 days ago
    I only seal when the weather is appropriate. Cool days with low humidity. As a result, I've never had a problem like you describe.
    $ 24.00
    The MOD Couple
    Creo Pinball
    Tools
    PinDoc Restorations
    $ 18.99
    $ 134.95
    Hookedonpinball.com
    $ 1,248.00
    $ 40.00
    Lighting - Backbox
    $ 8.95
    $ 109.99
    $ 68.00
    PinWorlds
    $ 139.95
    $ 79.95
    Hookedonpinball.com
    $ 26.95
    $ 7,599.00
    Little Shop Of Games
    $ 104.95
    $ 78.00
    $ 219.99
    $ 7.95
    Apparel - Unisex
    Pinball Wheezer
    $ 218.00
    $ 18.99
    $ 839.00
    $ 89.95
    $ 47.00
    The MOD Couple
    $ 5,999.00
    $ 22.00
