Recently picked up a decent Bally Atlantis. The only thing noticeably wrong is the sound. Most of the time the music does not work, sometimes cuts in and out and goes really loud. Call outs are there but no other sounds. It had the original battery with a tiny bit of corrosion on the ends so I removed it. Next to it
I’m noticing on the main board there’s a resistor that appears burnt out. I’m going to order replacement resistor, battery holder and an led kit. I just re flowed solder on all the points on the fuse board. I’m hoping the resistor is what’s causing the weird sound issues. Any insight would be appreciated
