Quoted from csab00:Hi!
I am trying to fix a Bally MPU what is working correctly if is starts...
it means i have turn on and off for couple of times then is ok.
This is completely random may 3 or 4,5 times i need to do it.
What components could be bad ?
Thanks in advance!
Battery damage in the power on reset area can lead to this symptom. If the reset signal floats or is stuck always high it sometimes just works but you need a few power cycles to get the CPU running ok. Bad 12v filter cap too.
When you turn on the game you should see a brief low signal at CPU pin 40 then it goes high and stays high. A logic probe will show the low to high transition if reset is working okay. If you don't see low to high at power on, there is a problem.
Measure ripple on the 12v filter cap. DMM set to low range AC volts and go across the 12v cap leads, much more than 0.25vac is generally considered too much for this system.
