(Topic ID: 203752)
Bally AS2518-18 Strangeness - 530 volts on TP2
By PinPilot
6 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 6 years ago by PinPilot
#1 6 years ago
So I rebuilt my power supply on my Mata Hari with the usual new rectifiers, and all seemed well. Voltages were a tad high on all the checkpoints, but pretty close to spec. I notice later my displays flickering, and one blank. I check the connections and they appear good.
Deciding to start at square one, I put a multimeter on test point 2 on the power supply and BAM %#) 530 VOLTS! I checked the four in4004 diodes and the resistor that comprise this circuit on the power supply, and they all test good. How on God's green earth am I getting 530 volts? And nothing was touched from when it was within spec.
So I'm gonna throw in the towel and buy some 5volt LED displays that do away with this nasty high voltage (anybody want to buy some original displays), but I'd sure like to understand what happened here! Please educate me if you can - I hate not understanding whats happening.
#2 6 years ago
All the other TPs still read fine? Sure your ground is good? Does reading stay the same if you unplug J3 from the rectifier board?
#4 6 years ago
TP2 is connected to the 230VDC supply via a high value resistor (R3) that results in unreliable readings with cheaper digital multi-meters.
Measure the other side of resistor R3 on the rectifier board to get a more accurate reading.
#5 6 years ago
OK, I am officially cut off for the day. I had my MM set on AC, which does show 530 volts, but when I switch to DC (as I should have to begin with) I see 230 volts.
I would erase this thread out of embarrassment, but perhaps it will be a cautionary tale to a future Pinsider.
I'm still buying the LED displays
$ 69.00
Pinball Pimp
$ 12.00
$ 18.95
$ 179.00
Pinball Pimp
$ 149.95
Allteksystems
1,450 (OBO)
Fredericksburg, VA
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
Third Coast Pinball
Troxel Repair
$ 48.00
3,500
Pittsburgh, PA
This page was printed from https://pinside.com/pinball/forum/topic/bally-as2518-18-strangeness-530-volts-on-tp2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
