(Topic ID: 85292)
Bally/Stern AS-2518 Club !
By mof
10 years ago
  • 3,894 posts
  • 369 Pinsiders participating
  • Latest reply 3 hours ago by pb456
  • Topic is favorited by 287 Pinsiders
There are 3,894 posts in this topic. You are on page 67 of 78.
#3301 1 year ago
Quoted from barakandl:
Yes, if the MPU is damaged in any way I will repair or replace it. Send me a contact form message on the website if you think the MPU has a problem and want to send it back.
Thank you barakandl. I appreciate your service. I’ll check your website.
#3302 1 year ago
Quoted from Phesson:
This is what I was thinking. It has a weebly mpu board. Do they still service these?
Webbly is still doing business I forget whom it is here on Pinside.
I don't think they offer "service" . IE you may not be able to send them a questionable board and expect them to debug.
Regardless; ask them via their website. It's right there on the board via silkscreen.
Nevermind; barakandl responded.
#3303 1 year ago
Also see this and make sure you are not noticing "phantom pops". The slings and pop bumpers may pulse with the flippers occasionally. This is some what normal and unavoidable. Phantom pops should not score points though in most cases.
Theory of operation talks about it.
https://arcarc.xmission.com/Pinball/PDF%20Pinball%20Misc/Bally%20Theory%20of%20Operation.pdf
#3304 1 year ago
Looking for a supplier for the C26 capacitor on Bally/Stern solenoid driver boards. They were custom made for Ed at GPE, but with his recent loss he is closing down his business, is out of stock on them and probably won't be receiving any more.
The cap is 150uF, 350 VDC, axial. I have searched Jameco, Mouser and a number of other sites to no avail. Richey will make you 100 with 28 weeks notice.
Does anyone out there have another source?
#3305 1 year ago
Quoted from Alan_L:
This place has a lot of old radio/TV capacitors, they have a 220uf @ 450 volts axial for 10 bucks.
https://www.justradios.com/cart.html
You can use a radial instead too, there's various ways of mounting them.
#3306 1 year ago
Quoted from frenchmarky:
Thmanks for the tip.. They do have a 150uf, 450v for $8.99, but Ed was at $5.00 before he ran out. Perhaps someone has them cheaper.
#3307 1 year ago
Two in the shop... mine!
#3308 1 year ago
Quoted from Alan_L:
I have an order arriving next week. Radial leads 150uF, 400V. Selling them for $7 plus shipping if you're interested.
#3309 1 year ago
Arrow usually has good prices on electrolytic capacitors. Free shipping if you buy enough stuff. Perks programs. Often can find coupons. These would all work on the driver board HV cap
Epcos (TDK) 150uF 450v. High reliability, high temp, low esr... nice specs $1.8. They don't have many in stock. Probably the best choice I see right now unless you like Nichicon or Nippon Chemicon.
https://www.arrow.com/en/products/b43547a5157m/epcos-tdk
Nichicon standard 150uF 450v $2.7
https://www.arrow.com/en/products/lls2w151melz/nichicon
Nichicon reduced size 150uF 400v $1.9
https://www.arrow.com/en/products/upz2g151mhd6/nichicon
#3310 1 year ago
Quoted from Alan_L:
TRY:
https://www.mouser.com/ProductDetail/CDE-Illinois-Capacitor/107TTA350M?qs=3tP%252BN51vMXcmcGDbhPL69A%3D%3D
It's not exact, but close.
#3311 1 year ago
BTW all the ones I linked at radial style. Just mount it like the C23 cap. There is drill holes to use a zippy tie and wire leads.
Nichicon discontinued the axial ones a couple years ago. Not very many options for the axial style anymore.
Did CDE buy Illinois Cap? That is a new one to me. The one linked above kind of looks that way. Hard to keep track of how often these companies buy and sell each other anymore. Anyways CDE / IC both a good brand with a long history. Although "Illinois" cap started making there product in China...
#3312 1 year ago
Well i am stumped, i hope i am just missing something stupid because that issue is aggravating me... Just finished a hardtop restauration on a Frontier, all is working well after typical adjustments, except the top lane B switch. It is widely inconsistent, not registering at all, to often registering twice on a single roll to sometime working...
I did:
Clean and adjust original switch, did not work.
Put a new leaf switch and adjusted, did not work.
change the diode, did not work.
change all the diodes of the other switches in same row, did not work.
remove new capacitors from switches in same row, did not work.
Checked visually switch in same row, nothing loose or wrong i can notice?
Swapped the original MPU for an Weebly, same issue still
reprinned the MPU wire connector for good form, did not work.
I am short of micro switch bracket to do a real test but it seems to be working fairly well putting one in parallel and doing some test.
Am i missing something here? all the other switches in the game works just fine. All diodes and caps are new under the PF. The top lane A and C near it work just fine...
#3313 1 year ago
Is the hardtop interfering mechically with the switch assembly?
#3314 1 year ago
Quoted from hisokajp:
I did:
I was thinking you could clip the switch lugs closed with an alligator wire, put it in switch test and try to get it to act up by wiggling/tugging on connectors, moving the pf up and down etc.
#3315 1 year ago
i did another very thorough pass through off ALL switches, making sure all solder of wires, diodes and caps were solid, that there was enough gap between every lugs and no short to anything nearby, even changed diodes on the cabinets switches. I am not sure exactly what it was but it seems it did the trick and now the B lane works flawlessly... perseverance paid off
#3316 1 year ago
Damn crickets . Glad you’re back in business.
#3317 1 year ago
I'm pondering rejumpering this working-great extra mpu-200 from my Stern Lightning so that it will work in my Bally EBD. Instructions all say the clock speed change involves jumpers E32 thru E35 but I went bat-blind trying to find those, can anybody point them out or is something else going on? Only ones I couldn't find. thanks
302663738_3298549157092300_3475802155891366255_n (resized).jpg302663738_3298549157092300_3475802155891366255_n (resized).jpg
#3318 1 year ago
these?
#3319 1 year ago
Oh there they are, man I just could NOT spot those, thanks!
#3320 1 year ago
Embryon issues
Looking for some advise as to what the issue might be….
Working on an Embryon, and the second to the left pop bumper was working for a few hits then dead, constantly doing this. So I change out the diode with a fresh 1n4004. Pop bumper works awesome!! Well, thought I was done and after a few games, other things started to crop up…knocker knocks frequently, only the far left pop bumper light comes on at the beginning of the game.
Now, before I added that diode, the pop bumper to the far right, occasionally, when I pressed on the skirt, would pop but some of the playfield insert lights would come on and off, as well. I didn’t mess with it, because it was working fine and it only did it a few times.
Those are my dilemmas, any help appreciated. I’m assuming some kind of matrix issue involved - there are still older diodes and capacitors lingering on other switches. Don’t know if that could be part of the problem…all I know is that the gremlins are getting me good this time!
#3321 1 year ago
Quoted from metalkatt:
Embryon issues
You need to start isolating when the issues occur and try to get more specific in your post. I can’t tell from your post which lights come on or when, and what issues have been resolved and which are still occurring. Perhaps let’s take them one at a time. Insert light issues are very likely going to be different from switch issues. So, is there a switch issue, and if so, what specific switch and what is happening? Let’s start with that. If we resolve it, we’ll move on to the lights.
#3322 1 year ago
Quoted from Nokoro:
So, initially I was getting a closed 5 switch(outhole) in the switch test. There’s two in the trough, the left one was stuck and broken…so I have another ordered to fix that error.
They asked me to fix one of the pops because it’s not activating when the ball hits the skirt. I continuously tapped on the skirt, and eventually it would start popping for 5/6 times until it was dead again. So, I figured, clean switch the contacts and change the diode. They were original and I had to get under the hood anyways, so I did that. Pop bumper works awesome now.
When I was tapping the other pops, I noticed the far right one would pop, but 7/8 insert lights would turn on and off at the same time. I found that odd…but it didn’t do it all the time.
So, I left the machine for the day, everything seemed to be working okay otherwise. Later that evening, they contacted me to let me know that the knocker was firing multiple times during a game and that the left pop bumper light was coming on and staying on, but the other 3 pops were not.
I’m waiting for video to see the issues, and I’m not going back for a couple weeks to attempt a fix. Figured rattling some other brains besides mine might help me get a better idea what’s up. I can’t imagine changing a diode would cause any of these issues but I’m open to all ideas.
Hope that clarifies the issues I’m looking to resolve….
Thank you for any help.
#3323 1 year ago
Thanks. I’m not familiar with the game. What in game events control the 7 and 8 insert lights?
If the pop bumper lights are controlled, you could have a stuck on transistor on the board. It is worth checking all transistors for those affected lights. If you don’t know how, there’s a good post that I can link when I get home later today.
I would also check all switches for shorts to ground. Maybe something got bent, and a switch or a lead is touching a lamp socket.
#3324 1 year ago
My Stars on location is not booting normally. If you power it on, the LED locks on. If you then quickly power cycle, it boots normally. I had this happen on my Diner, and I know it’s a different board set, but it ended up being a single capacitor in the reset circuit. Is there something similar for Bally/Stern games where it’s likely to be one specific thing most of the time?
Original board, remote batteries since I got it.
#3325 1 year ago
By far the number one problem I get emailed about after a customer puts in a new MPU board is solenoids are not firing in the right order or some are missing. This is almost always a connector issue between MPU J4 and driver J4. I created this chart to help to chart and identify what bit is the problem. When there is an open circuit connector issue between MPU J4 and driver J4 the input bit will pull high (red, 1). When there is a green zero on the right side, that is what coil fires when the input pattern on the left is given to the driver board decoder.
Tip. Switch over to Stern Hot hand or a MPU200 game as they do the solenoids in Q# order. Bally has no logical order and every game is different which is one more thing to try decode...
#3326 1 year ago
By far the number one problem I get emailed about after a customer puts in a new MPU board is solenoids are not firing in the right order or some are missing. This is almost always a connector issue between MPU J4 and driver J4. I created this chart to help to chart and identify what bit is the problem. When there is an open circuit connector issue between MPU J4 and driver J4 the input bit will pull high (red, 1). When there is a green zero on the right side, that is when the coil fires.
That is a problem with people expecting that just buying new boards and popping those in the game will fix all the problems. If there isn't troubleshooting first they can also damage new boards....
#3327 1 year ago
Quoted from desertT1:
WMS charges up a 33uF cap I think it is to delay the reset circuit. Bally is a bit different, no electrolytic cap to dry out and reduce the time like WMS, but the reset circuit is still not that complex. Check pin 40 of the CPU chip. You should get a low to high transition at power on. If it is floating or stuck always high might have some battery damage or blown out active part in the reset area.
Check the 82 ohm resistor. It likes to burn out and is involved.
#3328 1 year ago
Quoted from Robotworkshop:
I get to fix that too =D. I just added over voltage protection on the driver board. We'll see if it helps, have fixed a rash of blown out by over voltage MPUs lately.
#3329 1 year ago
While I fully expect to be able to track and fix the issue, this game is on location and everyone plays Stars. So while I troubleshoot I’ll take the easy way out and bought another MPU from you on Saturday.
#3330 1 year ago
would anyone have Bally Coin slide Assy they would be able to sell me? I am trying to put together a pretty hacked up coin door on my Frontier. thanks!
20220920_195339- (resized).jpg20220920_195339- (resized).jpgCapture (resized).JPGCapture (resized).JPG
#3331 1 year ago
Another problem just cropped up this afternoon. I have a Stern Wild Fyre (MPU-100) that I bought recently that was working. Got it home, stripped and cleaned the playfield, remediated some small alkaline damage (I hope), and fired it up. This was two weeks ago. Game booted, got all seven flashes, displays work, goes into attract mode. All tests with the coin door button pass: switches, solenoids, sounds, etc. But it would not start a game even with credits on it. Switch #6, Credit Button, shows up in Switch Test.
Now this afternoon, game won't boot, gets the flicker on the MPU LED at power up, a long pause and one flash, or sometimes shows flicker, flash, pause, flash, flash, and that's it. Voltage readings at all test points on the power supply board are correct, and before it quit booting all test points on all boards were correct.
I have replaced U7, U8 and U10 with no change. Do you think that I still could have some lingering alkaline cancer or perhaps is there something else i could try? Should I bite the bullet and buy a Weebly and turn this MPU into a rectangular frisbee? Please see pics below. Thanks.
20220927_220205 (resized).jpg20220927_220205 (resized).jpg20220927_220210 (resized).jpg20220927_220210 (resized).jpg20220927_220222 (resized).jpg20220927_220222 (resized).jpg20220927_220226 (resized).jpg20220927_220226 (resized).jpg20220927_220232 (resized).jpg20220927_220232 (resized).jpg20220927_220236 (resized).jpg20220927_220236 (resized).jpg20220927_220301 (resized).jpg20220927_220301 (resized).jpg
#3332 1 year ago
You'd have to check each trace with your meter to see if the corrosion has interrupted the Circuits
There looks to still be corrosion in the pics
Did you use the SnoBowl to clean it?
#3333 1 year ago
ive repaired boards with much worse corrosion... which are still in use on both my star treks.
#3334 1 year ago
Unless you enjoy board work and head scrstching I would just get a new board.
#3335 1 year ago
Quoted from vid1900:
I see an AMI chip, I know where I would start.
#3336 1 year ago
No, just the usual vinegar & distilled water and 99% alcohol rinse. Not familiar with SnoBowl. You mean the toilet bowl cleaner?
Quoted from gdonovan:
Bought some used 6821s from a good friend, now I'm up to 6 flashes. 43.3 VDC on TP5 on P/S board. Checking further.
#3337 1 year ago
Quoted from Alan_L:
The ZEP gel stuff from Home Depot is awesome, does a great job.
#3338 1 year ago
Quoted from Alan_L:
You won't get the 7th flash on the bench unless you provide 43V solenoid voltage or by temporarily jumpering the top of R17 and the top of R23.
#3339 1 year ago
Good news!
I have a '77 Bally Eight Ball so I decided to at least try its AS-2518-17 in the Wild Fyre and see what happens. Lo and behold the MPU in the EB is a MPU-100 also. Both boards had 9316A roms in U2 and U6 so I switched them and it works 100%!
Come play it at The York Show.
#3341 1 year ago
I have a Six Million Dollar Man machine that I just finished restoring the cabinet. I put the machine back together and it worked great. I did remove the batteries and installed a remote battery box since then. The machine still worked fine but now when I turn on the switch, the backbox lights up but the score displays do not and the machine doesn't go through it's normal startup sounds and lights. Per the manual in the troubleshooting area, it mentions for me to look for the green LED light on the A4 MPU board to flash seven times. If there is no light, it says to replace the MPU Module A4. My green LED light does not light up at all. Do I replace the MPU? Any other things I should look for before going that route? If I need to replace the MPU, where do you guys suggest I look for one of these (AS-2518-35-module less program memory or AS-2962-2 Complete Module)? About how much to they cost usually?
#3342 1 year ago
Quoted from pkurfess:
Double check all your connectors. Are they going to the right pins on the boards, and is everything lined up correctly with the connectors? Measure the voltage at the test points on the rectifier board and compare to the values in the manual.
#3343 1 year ago
Do NOT replace the MPU board until you determine where the game is losing power. The issue is likely upstream. Follow @nokoro's advice first.
#3344 1 year ago
Quoted from Nokoro:
I usually work on EM's so the SS machines are newer to me. Where would I be measuring the voltage please? Visual?
#3345 1 year ago
Check the manual via ipdb if you dont have it, for testpoints and voltage values
#3346 1 year ago
Various test points on the boards - here are the expected values (start with the rectifier board, then the solenoid board, then the MPU):
https://pinwiki.com/wiki/index.php/Bally/Stern#Attract_Mode_Test_Points
#3347 1 year ago
Quoted from Mathazar:
Thanks, I'll give this a try.
#3348 1 year ago
Quoted from Nokoro:
connectors are notorious with Bally's of this era...Nokoro is 100% correct...keep your money in your pocket for now
#3349 1 year ago
I thought this would generate vast amusement for our knowledgeable board members.
#3350 1 year ago
There's a fine line between amusement.....and terror.
Westminster, MA
2,600
Collegeville, PA
$ 18.95
$ 179.00
1,600 (Firm)
Butler, PA
$ 18.95
$ 29.00
RoyGBev Pinball
$ 5.00
Playfield - Plastics
3,900 (OBO)
Woodstock, GA
$ 22.95
$ 12.00
Metal-Mods
$ 12.00
Various Novelties
Pinball Photos LLC
$ 18.95
$ 10.95
£ 195.00
arcade-cabinets.com
$ 1,099.00
$ 100.00
This page was printed from https://pinside.com/pinball/forum/topic/bally-as-2518-club/page/67 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
