Quoted from mr2xbass:Am I having a Switch Matrix issue? Game is Centaur.
Issue: The "O" of the O-R-B-S and the "2" of the 1-2-3-4 drop targets do not register if they are the last one hit in each of their banks.
All eight target switches can be seen in Self Test, and in play, the "O" and the "2" register fine as long as they are hit first, second, or third of their respective 4-bank (issue is only when they are the last to fall). Also, though very seldom, the "1" of the 1-2-3-4 will not register even if it is dropped first.
One thing I observed, maybe helpful(?) : when the "2" is the last target down in the 1-2-3-4 and the switch has failed to register, if the "Spot 1-2-3-4" standup switch is hit, it will fire the plunger for the "2" drop, as it would if it thought the "2" was the next target to drop (but the "2" is already down so nothing happens).
The switches are definitely making contact when targets are dropped, verified w/ DMM. Also replaced the diodes on the "O" and "2" switches.
All eight switches are on the same strobe line.
Where should I look next? U10 6821 PIA?
I had the same thing happen on a Future Spa. The 4 inline drops and a 5th standing target are all on the same strobe. The PIA could not power it. In my case I was able to swap the two 6821s around and it worked.
