Quoted from pacman11:Alright So I am replacing a powersupply and I’ve got something incorrect. Game isn’t booting. This is what I have wired, I must have a wire out of place.. Thanks for the help..
What are your voltages?
Quoted from JethroP:What are your voltages?
When I turned it on the game buzzes so I shut in down fast. I don’t want to damage anything on it. The game did work with the old board but some of the wires were hacked pretty bad so I thought I’d clean it up and put a new power supply in it..
Quoted from pacman11:When I turned it on the game buzzes so I shut in down fast. I don’t want to damage anything on it. The game did work with the old board but some of the wires were hacked pretty bad so I thought I’d clean it up and put a new power supply in it..
Where's your manual schematics....
I would start buy checking every connection from
the transformer lugs to each PCB input.
Quoted from RocketFromTombs:And today I got a surprise in the mail:
And here is one head trimmed from the little connector piece between them:
I made a quick and dirty jig to support the kicker arm while I pounded out the roll pin and removed the old broken head. Then I put the new head on and pounded the pin back in. (I highly recommend using some sort of similar jig to support the kicker when you're pounding, and use the proper size center punch if you can!)
And here it is all assembled:
I sent some pictures and feedback to Swinks, and they are now available here:
https://www.shapeways.com/marketplace?type=product&q=swinksc-1062
Unfortunately, I am just starting a playfield swap, and won't be able to play test these for a while...
That said, the new kicker head seems to fit the same as the original, and I am very, very happy with how this turned out!
Am I missing something. These are sold by PBR and Marco for half the price?
Quoted from pacman11:Old one just don’t see what color wire I switched up..
You cut all the wires? I hate taking any length off that isn't needed. Last time I replaced one of those board I took lots of reference photos then unsoldered and moved over wires one at a time. Did a few at the end all at once but had the photos as backup just in case.
Quoted from Robotworkshop:You cut all the wires? I hate taking any length off that isn't needed. Last time I replaced one of those board I took lots of reference photos then unsoldered and moved over wires one at a time. Did a few at the end all at once but had the photos as backup just in case.
I just trim a little bit off for reference, I saw a repair tech do this a few years ago. Someone cut them shorter and used electrical tape to extend them with different color wires which make it even harder to figure out. I’ve done a few of these with no problems in the past but I just can’t figure out what I switched up on this one..
If someone could verify the color of E11 wire that would help me..
Thanks, I see where I screwed up. The two wires I thought. Now I’ve got other problems coils aren’t working now. Fuses are good too. Damn might of messed something else up.
Quoted from pacman11:I just trim a little bit off for reference, I saw a repair tech do this a few years ago. Someone cut them shorter and used electrical tape to extend them with different color wires which make it even harder to figure out. I’ve done a few of these with no problems in the past but I just can’t figure out what I switched up on this one..
In the one picture there appears to be an extra blob of solder near one of the blue wires. If it is get rid of it. Otherwise it will probably fall across something later and cause a short.
Maybe you saw someone do it but I don't think it is a good practice. I can sort of understand before digital pictures but now there is no reason for that. If is done every time that explains what you are working on one with extension wires added.
Quoted from pacman11:Thanks, I see where I screwed up. The two wires I thought. Now I’ve got other problems coils aren’t working now. Fuses are good too. Damn might of messed something else up.
Check the fuse under the playfield
Quoted from jj44114:Am I missing something. These are sold by PBR and Marco for half the price?
The Bally kicker heads have been “out if stock” for some time now. The last time I called in an order to PBR he said they were unavailable.
Quoted from RocketFromTombs:The Bally kicker heads have been “out if stock” for some time now. The last time I called in an order to PBR he said they were unavailable.
In stock at Marcos. $2/ea in quantity of 10 or more. $3/ea if you need just a few.
Look upthread. Swinks(?) is making replacements now/soon.
Quoted from Mathazar:In stock at Marcos. $2/ea in quantity of 10 or more. $3/ea if you need just a few.
https://www.marcospecialties.com/pinball-parts/03-7501
Those are for Williams style kickers heads not OEM Bally style kickers heads from the 1970's-1980's.
Quoted from vec-tor:Those are for Williams style kickers heads not OEM Bally style kickers heads from the 1970's-1980's.
Whoops.
Quoted from guitarded:Look upthread. Swinks(?) is making replacements now/soon.
Yes, he is. I am the person who approached him and asked him to do so. He sent me a pair to test out before he made them available to the public, and I got them a few days ago. They are now available here: https://www.shapeways.com/product/EYDX5QLAU/bally-sling-shot-arm-cover-plastic-c-1062-pair?optionId=156965939&li=shops
Quoted from RocketFromTombs:Yes, he is. I am the person who approached him and asked him to do so. He sent me a pair to test out before he made them available to the public, and I got them a few days ago. They are now available here:
Thanks to the BOTH of you.
Now I think I might need some Pink Ones for my Dolly Parton.
Quoted from guitarded:Thanks to the BOTH of you.
yep, now available in 10 different colours so you can customise your game a little
Dolly Parton fans I thought I would share
Some pics Kruzman playfield coming
Should look nice
Quoted from whitey:Dolly Parton fans I thought I would share
Should look nice
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
That chrome is pretty sweet.
just uploaded a new product to Shapeways - Roll Over Button now EXTENDED 1mm more to accommodate the Outer Edge Hardtop playfield overlays. They still will seat the same into the playfield and connect the same under the playfield but have 1mm extension in the head to accomodate the Hardtop thickness. Available as singles or in sets of 5 in multiple colours.
https://www.shapeways.com/marketplace?q=swinksbutton&sort=newest
I just got a Future Spa and while going though it I've found that the only problem it has is the "P" light (directly under the center target) will not operate. I know the bulb is good and so is the wiring. I've looked in the manual and my first guess would be to replace Q29 on the light board. Does anyone know what part number this would be and is this a step in the right direction to get the light working? My first thought is "2N5064 SCR". Thoughts?
Screen Shot 2020-05-08 at 11.22.01 AM.pngQuoted from Jakers:Does anyone know what part number this would be and is this a step in the right direction to get the light working? My first thought is "2N5064 SCR". Thoughts?
Part numbers are often found on other pages of the manual, these look like to be MCR-106-1, available from Marco (among others)
https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=mcr-106-1
Get with Ed at GPE, he likely has these and or substitutes as well.
pasted_image (resized).pngQuoted from Jakers:Does anyone know what part number this would be and is this a step in the right direction to get the light working? My first thought is "2N5064 SCR". Thoughts?
Original is a 2N5060, but a 2N5064 is perfectly fine as a replacement (it can operate at higher voltages).
Atari_Daze the MCR106 SCRs are the ones marked on the circuit diagram with two stars ** and are the physically larger ones. It's strange the notes you posted don't mention it because I'm sure I've seen it in other lamp driver board schematics.
Quoted from Quench:MCR106 SCRs are the ones marked on the circuit diagram with two stars ** and are the physically larger ones. It's strange the notes you posted don't mention it because I'm sure I've seen it in other lamp driver board schematics.
Old file on IPDB I suppose.
Quoted from Atari_Daze:Old file on IPDB I suppose.
Ah, I see what's happened, the notes you posted are from the auxiliary lamp driver board which only has MCR106 SRCs. The main lamp driver board schematic on IPDB has the notes section partly chopped off.
It should look like this, so all good
Thanks, guys! I found them on PinballLife and placed an order. Fingers crossed, I'll have a 100% functional Future Spa soon.
I am having the same issue on my Dolly Parton.
O Target and Y Center Lamp are both not working, but fine. I am guessing it is component related n the Lamp Board.
I have not ordered up the part as this is new to me (Board Work) and frankly, scares the hell outta me.
Check out my website for Tech Charts on Future Spa and Dolly Parton.
You can find them both in the Bally section and in the Tech Charts section.
http://www.inkochnito.nl
Thanks Inko, that's super handy to have!
So it looks like I need replcements for 2N5060 in each of those positions. Anything else I should change along with them?
Need a picture of the J1 and J2 connector to figure out the wiring. I’ve got a wire out of place that came out of a connector for my Bally pin on powersupply. Thanks!
Quoted from pacman11:Need a picture of the J1 and J2 connector to figure out the wiring. I’ve got a wire out of place that came out of a connector for my Bally pin on powersupply. Thanks!
Manual has wire color and pinout.
Quoted from vec-tor:Manual has wire color and pinout.
No manual and my eyes aren’t the best to read it anyways. Getting older sucks!
Quoted from pacman11:No manual and my eyes aren’t the best to read it anyways. Getting older sucks!
What game... What connectors ?
Quoted from guitarded:Thanks Inko, that's super handy to have!
Reflow the pins on the lamp driver board.
It solves 90% of the problems.
Sometimes acid damage is present on the top or bottom traces.
Quoted from vec-tor:What game... What connectors ?
Bally Lost World- J1 and J2 on power supply. I need a picture of the connector wires..
O.K.
when facing the transformer bridge power supply...
[ J1 ] playfield connector is located to the top left.
pin1 is on the left, pin 8 is last pin on right.
Factory: connector's open locking pins on top.
[ 1 I 2 I 3 I 4 I 5 I 6 I 7 I 8 ] --connector J1
-50 40 n.u. key 70 60 20 10 -- wire color code
wires:
1) 50 -- white
2) 40 -- green
3) N.U.
4) Key
5) 70-- orange
6) 60-- brown
7) 20-- blue
8) 10-- red
part two
[ J2 ] playfield connector is located to the top right.
pin1 is on the left, pin 10 is last pin on right.
[ 1 I 2 I 3 I 4 I 5 I 6 I 7 I 8 I 9 I 10 ] --connector J2
-38 40 n.u. spare 41 30 20 key 70 40 -- wire color code
Note: 22 awg small dia. wire. -- 18 awg large dia. wire.
wires:
1) 38 -- yellow-black, 22 awg.
2) 40 -- green, 22 awg.
3) N.U.
4) spare ground
5) 41 -- green-red, 22 awg.
6) 30-- yellow, 18 awg
7) 20-- blue, 18 awg
8) key
9) 70 -- orange, 18 awg
10) 40-- green, 18 awg
This page was printed from https://pinside.com/pinball/forum/topic/bally-as-2518-club/page/41 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
