(Topic ID: 85292)
Bally/Stern AS-2518 Club !
By mof
10 years ago
  • 3,887 posts
  • 369 Pinsiders participating
  • Latest reply 5 days ago by Knxwledge
  • Topic is favorited by 287 Pinsiders
There are 3,887 posts in this topic. You are on page 28 of 78.
#1351 5 years ago
Quoted from Robotworkshop:
Does anyone happen to have a part number or link to the correct flipper relay on the Bally/Stern driver board?
https://www.greatplainselectronics.com/proddetail.asp?prod=LB2-48DP
#1352 5 years ago
Thank you! I need to order some other parts from them and will just add on to the order.
#1353 5 years ago
Question about the Bally and Stern Solienoid driver boards. It it my understanding that the regular Bally AS-2518 and Stern SDU-100 boards are interchangeable. Upon looking over a couple versions of the Bally board I noticed something odd on J3. On one of the Bally boards pins 18-24 are all tied together on the back of the board. On a different Bally board and the Stern board pins 23 and 24 are separate from pins 18-22.
I'd like to verify that there isn't a solder bridge on that first Bally board or if it is ok if the other boards should be bridged the same to tie grounds together at the board.
#1354 5 years ago
A3-18 thru 24 are all ground connections.
Yes, you can connect them.
On Stern SDU boards they kept the Solenoid ground seperately and maybe on some early Bally boards.
Also follow the instructions as layed out on www.pinwiki.com
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Solenoid_Driver_Upgrades
Peter
http://www.inkochnito.nl
#1355 5 years ago
Quoted from Inkochnito:
Peter
Hello Peter,
I've added the extra jumpers on the board but the Wiki never mentioned tying the grounds on pins 23 and 24 to the others on 18-22 or that some versions already had those tied together. I guess if they should be then that would be good to update the Wiki. I didn't know there was a difference until I had a couple different versions of the board and thought one may have had a solder bridge.
#1356 5 years ago
Another difference between the two solenoid driver boards is that Bally fitted a 2.2 ohm resistor at R50, while Stern fitted a 4.7 ohm resistor which results in their 5V supply being a fraction higher (around 5.2 volts compared to Ballys 5.1 volts.).
#1357 5 years ago
Hello Peter,
Can you post some images of the board in question?
Maybe the type of board or markings on the board.
#1358 5 years ago
Quoted from Quench:
Some Stern driver boards do not have a high voltage fuse.
#1359 5 years ago
I'll get some pictures of the boards and post them.
#1360 5 years ago
there is at least four different stern driver boards. The last ones they made are the nicest with silk screen information printed all over. The HV circuit is different on those too. It seems like they attempted a shutdown circuit but the damn thing burns up when the HV transistors short like the earlier HV circuit does.
#1361 5 years ago
Attached are pictures of the STERN SDU-100 B432 board out of a Flight 2000. I've cleaned the board, installed a new 5V cap, replaced a bad driver for the lockout coil, and added the extra jumpers to tie the 5V lines together and provide the common grounds. On this board pins 23 and 24 don't tie into the other grounds like one of the Bally boards I have. Maybe these should also be jumpered to the other ground connections next to it on pins 18-22.
I have a new relay on the way and need to fix a couple traces for the left flipper. Then I can put on the HV shield and it should be done.
20181120_191827 (resized).jpg20181120_191827 (resized).jpg20181120_191846 (resized).jpg20181120_191846 (resized).jpg
#1362 5 years ago
My Xenon project is in need of a transformer and rectifier board. Does anybody have one to sell? I don't mind rebuilding it.
#1363 5 years ago
This Bally AS-2518-16 is very similar to the STERN board in that it also has the ground for pins 23 and 24 separate from pins 18-22. Both this board and the STERN board lack the extra fuse for the display power.
20181120_203804 (resized).jpg20181120_203804 (resized).jpg20181120_203821 (resized).jpg20181120_203821 (resized).jpg
#1364 5 years ago
This Bally AS-2518-22 has the ground for pins 18 through 24 all tied together. This board has a fuse for the display power.
Since this looks like a newer board it seems that maybe the earlier boards could be updated the same way. Is anyone already combining the grounds like this on the earlier boards?
20181120_203853 (resized).jpg20181120_203853 (resized).jpg20181120_203906 (resized).jpg20181120_203906 (resized).jpg
#1365 5 years ago
Happy Thanksgiving and a once again functioning Playboy after replacing this rectifier board.
IMG_1754 (resized).JPGIMG_1754 (resized).JPGIMG_1756 (resized).JPGIMG_1756 (resized).JPG
#1366 5 years ago
Quoted from Buzz:
[quoted image][quoted image]
I would like to have that old board if you have no need for it.
#1367 5 years ago
I would combine those grounds.
It is always better to have multiple ground wires.
I've done the same kind of upgrade to the Gottlieb System 80 driver board.
Works perfectly.
#1368 5 years ago
Took my kid down to play (he's 2 1/2) and for the first time (since he's an impatient player ), I noticed that even during the boot up cycle, my Strikes/Spares has functioning flippers. Other than 'it's incorrect', is there any reason to rush to fix it? Pretty sure I know how, just trying to figure out where in my list of fixes I need to prioritize it.
#1369 5 years ago
Quoted from statictrance:
I had a solid state BlackJack that had the same issue. The flipper relay was fine but the transistor array that then fires the larger secondary coil transistor had failed shorted. I had flippers from the instant the power was on. No big deal but it was weird to tilt the machine and still be able to play.
#1370 5 years ago
Here's a Nitro Ground Shaker that I just posted for sale:
71808
#1371 5 years ago
That should read:
SOLD!
Partially shopped/refurbished - “Nitro Ground Shaker, Bally 1980. 100% working condition. Brand new backglass, plastic set, drop targets AND a brand spanking new Alltek Ultimate MPU for long term error free oper...”
2019-01-08
Jarrettsville, MD
1,395
Archived after: 1 day
Viewed: 516 times
Status: Sold for $ 1,395
Contributed to Pinside
#1372 5 years ago
I’ve searched and can’t find the answer.
What type of Diode for an Evel Knievel Slingshot coil?
#1373 5 years ago
Quoted from Aladdin:
1N4004
#1374 5 years ago
Guess you picked the wrong week...
#1375 5 years ago
Quoted from pinfixer:
This is a classic "filter cap has died" description. Replace C23 on the solenoid driver board and this should clear up the reboot problem. While you're at it be sure to resolder any "cold solder" connections on the SDB at the same time. Pinwiki.com has a great section about updating the SDB which cleans up a couple of ground issues and gets rid of the pesky external jumper between pins 13 and 25 on J3. If the external jumper is flaky you can get the reboot issue too, but I'd put good money on C23. Whenever I get a game, C23 is the first thing I swap out no matter what. I usually use 15k-20k with a voltage rating of 25-35 volts. They're cheap and Bigdaddy sells a rebuild kit for the SDB for about the price of just the C23 cap alone.
Is there a way to test these caps or do you just replace them? I have a Strikes and Spares that boots up but no solenoids work,even during self test. The MPU works fine and even scores a game and ball count/credits. (No solenoids work and I get power to coils) I bought this machine with no boards in it, installed alltek MPU, a rebuilt power supply/rectifier board and repinned connectors, used (UNTESTED) solenoid driver board and a used tested lamp board.
#1376 5 years ago
Quoted from Heaterguy:
Just replace them. They dry out over time and therefore don't filter the DC as well. I don't even mess with them, I clip them and replace them before I even start testing or rebuilding the board. To your point about the solenoids, the filter cap is for the +5 volt logic section and completely independent of the solenoid voltage. I'd suggest checking the under playfield fuse and fuse holder. I'll bet it's toast.
#1377 5 years ago
Thx.
I plan on replacing them. I believe they are original.I already checked the fuse (s) also cleaned the fuse terminals.
Any other thoughts?
I am getting 44 volts to coils.
#1378 5 years ago
Any other thoughts?
Measure the voltage at TP3 on the solenoid driver board. If you don't measure 5 volts then re-terminate the brown-green wire that runs between pins 13 and 25 at connector J3 or just solder a wire from TP1 to TP3 on the back of the solenoid driver board.
#1379 5 years ago
What Quench said - Do the TP1 to TP3 wire mod on the back of the board to solidify that 5v. I've had coils drop out on my Big Game and F2K in the last few weeks - both resolved in 5 minutes by that mod. (and I'd repinned the connector on both)
#1380 5 years ago
If you look at previous posts in this thread I have some pictures of a few different Bally and Stern driver boards that I added that jumper for the +5V as well as a couple for ground mods. Definitely helps make a solid game.
There also some extra jumpers for the early bridge/power boards too.
#1381 5 years ago
Quoted from Quench:
Thanks, I think LOL....Wierd stuff is happening, on game start the pop bumpers pop instead of chimes.
I soldered the jumper because I was not getting voltage and now solenoids fire but the pop bumpers are firing instead of the Chimes, the out hole and saucer do not fire (including when in self test) During self test when the Chimes should fire, the pop bumpers fire and one of the left lower slingshots fire. Same thing during game play. I'm certain the J plugs are connected correctly to the solenoid driver board I even verified the wire colors in the connectors and re pinned them. I have the correct game configured for the alltek mpu. I am going to do a memory clear and reset for strikes and Spares and see what that does.
#1382 5 years ago
Repinning or reflowing connectors is a likely fix. I fixed a mata hari with this same issue recently, I think it was the right side connectors on the MPU.
#1383 5 years ago
i repinned the .156 pins, dont have the small ones for the red mpu connectors though.
#1384 5 years ago
Save yourself a lot of grief .. re-pin ALL connectors, both male & females. Been there, done that.
Time consuming, yes.
#1385 5 years ago
Quoted from dasvis:
God I hate it, still have about a hundred to go on my system 1 Gottlieb Genie.
I plan on repinning all of them on this game however I don't think that's the problem there's some really wacky stuff going on when the pop bumpers are firing instead of the Chimes
#1387 5 years ago
now solenoids fire but the pop bumpers are firing instead of the Chimes...
As everyone said, you've got a connector issue on the signals between the MPU board and the Solenoid Driver Board (SDB) that indicate which solenoids to activate.
I don't have facebook so can't see your video but from your first description, the signal with issue is the red-white wire between MPU J4 pin 1 and SDB J4 pin 3. You should just re-terminate all wires on those connectors though.
#1388 5 years ago
Quoted from Quench:
Yes I need to get some of the small Molex pins because I don't have any for the red connectors and you (and others) are certainly correct.... I scraped the red white wire on pin 1 of j4 and now it is not miss triggering however the chime still doesnt work so I will have to get some of the small pins and go to work thank you all for the excellent advice.
#1389 5 years ago
Exactly which solenoids are not working in solenoid test mode - are any still activating at the wrong time?
#1390 5 years ago
Well currently none of the solenoids are working in self test mode but when I scraped the pins on j-4 now they are loose I just need to replace them they are obviously shot. I'm pretty happy though because I saved this machine from the scrap Heap convinced the cellar not to part it out bought it for $100 it had no boards or power supply just a populated Playfield and the displays ( two of which are out) it took me a year's time to get around to this thing but I collected all the boards and bought a new alltek mpu. The wiring harness was hacked at the rectifier board someone had doubled up the two GI lighting circuits on to the first two pins and soldered them. So I have made a lot of progress just need to get those doggone Tiny pins and tons of them it looks like LOL
20181203_185118 (resized).jpg20181203_185118 (resized).jpg20181203_213318 (resized).jpg20181203_213318 (resized).jpg20181205_211508 (resized).jpg20181205_211508 (resized).jpg
#1391 5 years ago
Glad you're saving this ol' girl. Keep at it! Sounds like the terminals at the MPU J4 connector got hit with battery corrosion from the original MPU board.
#1392 5 years ago
Quoted from Piparoo:
Thanks for the lamp advice fellas. Has anyone had success with no flicker bulbs in the switched lamps, like comet pinball's optix bulbs? With a game like NGS, it would be less expensive to go with the no flicker bulbs for the switched lamps, even at $2-$3 a pop, than spring for the $100 alltek board.
The issue in games like Nitro Ground Shaker is different and the no flicker bulbs would still likely show problems.
There is a fix that would cost all of one dollar tho. Buy a pack of 470ohm resistors on ebay. Solder the 470R across any lamp that shows flickering. Not all lamps will need a resistor. Use lamp test to find the ones that do.
A No Flicker bulb would probably be a good choice for GI tho in that game. I assume no flicker bulbs would have diodes and a capacitor in them that helps the LED stay lit even on an AC or pulsing supply that goes down to zero which shows up as the strobe / flicker effect.
#1393 5 years ago
Quoted from barakandl:
I've used Comet 2SMDs in the GI with good results. For controlled lamps, Siegecraft lamp boards have been good. Just make sure they're getting 5V and you should be able to use any LEDs without the strobing effect. Again, I prefer Comet 2SMDs.
Or soldering resistors to lamp sockets is another alternative like you mentioned.
#1394 5 years ago
I soldered the jumper because I was not getting voltage and now solenoids fire but the pop bumpers are firing instead of the Chimes, the out hole and saucer do not fire (including when in self test) During self test when the Chimes should fire, the pop bumpers fire and one of the left lower slingshots fire. Same thing during game play. I'm certain the J plugs are connected correctly to the solenoid driver board I even verified the wire colors in the connectors and re pinned them. I have the correct game configured for the alltek mpu. I am going to do a memory clear and reset for strikes and Spares and see what that does.[quoted image]
I can see a problem with the print headers.
It's not unlikely that there are more pins bad.
Look at the red circle....
#1395 5 years ago
Good eyes Inkochnito ^^^
Inspect the soldering on the other pin headers in case more need to be resoldered.
#1396 5 years ago
Quoted from Quench:
Good eyes inkochnito ^^^
Earlier in this thread there was also the discussion about combining the grounds for those last two pins with the group above. It looked like that was done at the factory on later boards.
#1397 5 years ago
Quoted from Quench:
Should just replace the headers anyway. No doubt the plating has been compromised.
#1398 5 years ago
Wow Thank you thank you thank you! Upon close inspection there are 3 other ones even worse. (Loose)
I did not even think to reflow the pins as I have not had to do that except for one other machine. Will definitely do that when I replace C 23. One more question I have is the smaller red Molex connector pins....are they .100 or .093 Size? I have .156 trifuricons and re pinned those already but need about 200 of the smaller ones and don’t have any, as I have not had to do these type before. Do they remove the same way as the .156 pins do?
#1399 5 years ago
The red molex connectors use the .100 pins.
Yes, the same way as the .156 pins.
Do the ground upgrades as mentioned in the Pinwiki.
They are really a MUST do.
#1400 5 years ago
Will definitely do so thanks again.
$ 69.00
Pinball Pimp
$ 18.95
$ 169.00
$ 18.95
$ 179.00
Pinball Pimp
4,200 (OBO)
Springfield, MO
$ 12.00
$ 18.95
$ 42.00
PinballReplacementParts
$ 18.95
$ 29.99
Pinball Shark
3,000 (OBO)
Bay Shore, NY
1,800
Cape Coral, FL
$ 100.00
$ 69.00
Pinball Pimp
$ 12.00
$ 69.00
Pinball Pimp
Retro Electro Designs
$ 9.95
$ 69.00
Pinball Pimp
$ 12.00
4,750 (OBO)
Bay Shore, NY
This page was printed from https://pinside.com/pinball/forum/topic/bally-as-2518-club/page/28 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
