My previous 2 machines were post '86 and good condition, just needed a clean and plastics.
I have just gotten my first real project that is going to either kill me, or work well eventually.
It's a Future Spa, and came to me with the words that "the displays don't work, so cannot test it. But the rest is good." Famous last words.
Well....that is the last thing I am going to worry about for now. Half the boards are unplugged, and there has definitelty been work on the rectifier board, the MPU and possibly other boards. Not even going to attempt to boot it until I get boards checked. Then I can see if the displays are working or not. I have a lot fo work to do, and a lot of learning to do. But it gets me in the club I guess.
Considering sending the boards overseas to the USA to get checked. Can't afford to just replace with Allteks.
About half of the board is covered with thick mylar. Most of the inserts have a little dishing/cupping, but are in place. Not sure what to do. If I pull the mylar, I might lose a lot of artwork I cannot redo myself. If I leave the mylar over the inserts, it is hard to repair them. What do you suggest?
Some mylar in isolated places has bubbled and wrinkled a bit. As I said...I am hesitant to remove all the mylar, since once you start and paint starts coming off..there is no going back. In general, the playfield is in good condition with very little wear otherwise. And Future Spa has complicated art that would be a bear to have to redo. Do I cut off certain areas of mylar that are peeling, and leave the rest that is ok?
Chaos
