Quoted from Coyote:Really technical and specific question -
Does anyone know the address of SW33 (The 'reset' switch)?
Tryin' to modify my ROM revision to have that button enter a credit when not in test mode, and just trying to find the call.
-Mike
I programmed my own testroms for those Bally 2518 CPU boards and also used S33 to start a socket test. S33 is connected to the CPU /NMI line; an NMI routine will be started after pressing this switch. The /NMI vector (or start address of the /NMI routine) is located at $FFFC and $FFFD ($7FC and $7FD in 2kB ROM, $FFC and $FFD in 4kB ROM), HSB - LSB. In this routine you could add an INC <address creditcounter> if there is space and after you resolved the address where the creditcounter is stored in RAM. And correct the checksum data when you're done. Is this an answer to your question or did I misunderstand?
Marco
