I've got a Bally Aladdin's Castle (2 player) that I'm working on. It's mostly working but having some issues. I have not worked on many EM's so I thought I would see if anyone can help me out. I picked up a copy of the manual and schematics. Here is what is going on:
1 - The outhole solenoid is not kicking the ball into the shooter lane, so the score motor keeps running until you manually move the ball off the outhole switch. Wiring to the solenoid is good and the solenoid tests fine.
2 - Player 2 10,000 score reel will not attempt to reset to zero at the start of a game and the score motor will keep running. If I manually move it to the zero position, the game will start up. It advances fine during game play.
3 - The GI lamps are all off when you start a game. As you hit various switches (like the inlane switches), the GI and insert lights will temporarily come on as it's processing the switch hit but then they go off again.
If you hit either of the two rollovers in the Aladdin's Alley turn around, the GI lights and the insert lights will come on and stay on until the ball drains then turn off again once the next ball is in play.
4 - The Same Player Shoots Again light is on when you turn on the game (only light lit on playfield and no GI) and stays on until you shoot one of the Aladdin's Alley roll overs. It will come back on properly when you earn shoot again.
Any ideas?
