My 10k score reel is getting hung up at reset and sometimes during standard scoring (although not as consistent) . The coil fires intermittent and sometimes will stayed pulled in and wont release until several seconds after I turn game off. I had the same issue a while back and thought I took care of it with the end of stroke switch clean and adjust. The reel is completely clean and I cant get it to hang up at all manually advancing it. I took the reel apart no issues there. I checked jones plug but have continuity. All 1000 pt relay switches are cleaned and gapped and the reset relay is the same. 3 postion switches on 10k are ok. 9th position on 1000 is ok.
