(Topic ID: 251524)
Bally 7 Digit Display Expansion added to replacement MPU
By barakandl
  • 25 posts
  • 15 Pinsiders participating
  • Latest reply 2 years ago by Dakine747
  • Topic is favorited by 9 Pinsiders
#1 4 years ago
BALLY SEVEN DIGIT DISPLAY EXPANSION INFORMATION
Bally / Stern replacement MPU Revision 15 and later supports seven digit displays with some wiring modifications for the following games.
Dolly Parton
Future Spa
Harlem Globetrotters
Kiss
Mystic
Nitro Ground Shaker
Paragon
Playboy
Rolling Stones
Silverball Mania
Space Invaders
Six Million Dollar Man
Viking
Voltan Escapes Cosmic Doom
Because these games use the PIA port that is normally for digit 7 to control the sound board additional hardware and software is required for seven digit displays.
7 DIGIT DISPLAY SETUP INFORMATION
EXTRA ITEMS REQUIRED THAT ARE NOT INCLUDED WITH THE MPU:
22awg wire
Wire insulation. Shrink tubing or equivalent.
Zip wire ties.
1pc - Four pin 0.100" Housing. Molex 22-01-2047 or equivalent.
3pcs - 0.100" crimp pin. Molex 08-52-012 3 or equivalent.
4pcs - 0.156" crimp pin. Molex 08-50-0108 or equivalent. *** If your game is using IDC connectors at the displays you will not need this.
7 digit displays. Plasma or LED will work fine. If using Stern 7 digit plasma display board solder bridge connector pin 11 and pin 12 together.
INSTALLATION
Run a new wire to pin 12 of each display connector. Start at the last display in the wiring harness run and follow it between all seven digit displays (not the credit display). If you have IDC connectors use a punch down tool or a flat blade screw driver and let the wire pass through the connector except for the last display in the wiring harness run. If you have molex connectors preform a double crimp at each display besides the last one in the wiring harness run. Keep the wire long enough past the first display in the wiring harness run to reach the top left corner of the backbox. The green wire in the picture below is the added connections.
Move MPU J1 Pin 5 to the new added connector MPU J6 Pin 1. This is a typically a white wire with no stripe for digit drive five. You may need to extend the length of this wire if it will not comfortably reach MPU J6.
Move MPU J1 Pin 6 to the new added connector MPU J6 Pin 3, This is typically a white wire with a black stripe for digit drive six. You may need to extend the length of this wire if it will not comfortably reach MPU J6
Connect the wire you ran between pin 12 of each display to MPU J6 Pin 4. This is for digit drive seven.
Move both display count jumpers from 6D to 7D. 7D jumpers is only used for the special 7 digit expansion software, otherwise 6D is always used.
Zip tie and add all the extra wiring to the wire support clips.
Set the game software to the seven digit display version and turn on MPU game option DIP switch 21. See the game selection setup sheet for more information about software.
Install the seven digit displays and you are finished.
Over exposed image to see all digits lit up.Over exposed image to see all digits lit up.
Thank you Oliver Okaegi for the idea and software.
*** Note about Meteor Seven Digit *** Wire digit seven of each display to MPU J1 Pin 7.
MPUs can be purchased in the Pinside marketplace or at https://nvram.weebly.com
#2 4 years ago
Very nice way to handle this!
#3 4 years ago
Great stuff, very welcome feature addition!
#4 4 years ago
I like it!!!
#5 4 years ago
Thanks for your contributions to the hobby!
Platinum trader, buy all products with confidence!
1 month later
#6 4 years ago
barakandl do you know of anyone that has converted their Meteor to 7 digit displays using your MPU? Working on getting the parts together now. Thanks.
3 months later
#7 4 years ago
Quoted from TaylorVA:
Last night I rolled past my previous high score on my 3 ball game. It was 828,280 and when my final score rolled over 1 million, it showed 24,400 or something close to that with the first left digit out of course. It couldn't register my high score as I went over 999,999?? Is that true for a normal ROM code 6 digit diplay Meteor?
#8 4 years ago
Is there a reason why Embryon can not be converted?
#9 4 years ago
Quoted from CUJO:
On standard 6 digit displays, this is correct behavior. Are you saying you've converted to 7 digit displays, but this is happening?
#10 4 years ago
Quoted from RC_like_the_cola:
No, still have the original 6 digit displays.
#11 4 years ago
The cheaper way is to use a "divide by 10" rom. Makes 1000 pts only worth 100.
#12 4 years ago
Great mod.
66C92E2D-8B08-443F-A7F5-52E8CF8F9365 (resized).jpeg66C92E2D-8B08-443F-A7F5-52E8CF8F9365 (resized).jpeg
2 months later
#13 3 years ago
Wish this worked on some of the other early stern names like Lectronamo and Magic.
#14 3 years ago
Quoted from wolffcub:
It's coming. I have Magic just about finished... You in a position to beta test it? i.e. do you have an EPROM programmer? Note if you're using a factory MPU-100 board, you'll need to upgrade it to support two 2732 EPROMs.
#15 3 years ago
Quoted from Quench:
I do not have a programmer and yes I’m using the factory board. Point me in the correct direction on how to upgrade the mpu and I would not mind testing.
#16 3 years ago
I do not have a programmer.
Have you got someone that can program 2732 EPROMs for you? Note I'm talking about Magic 7 digit (real and virtual) support for now and the update also includes many other enhancements. This will be used as the template for other Stern MPU-100 games to support millions scores.
Here's the MPU-100 board mod to support two 2732 EPROMs. Note your factory 9316 PROMs won't work with this modification.
https://pinside.com/pinball/forum/topic/converting-a-bally-17-to-35-mpu-with-fo597-service-bulletin#post-5270218
Of course @barakandl's MPU board will be able to directly support the ROM code upgrade.
PM me when you work out how you're going to get your EPROMs programmed.
#17 3 years ago
Quoted from Quench:
Of course barakandl's MPU board will be able to directly support the ROM code upgrade.
Stupid question but what kind of eprom programmer is required? are the fairly reasonable in cost? Is it something a dummy like me could learn to do?
What are the other enhancements you mentioned?
#18 3 years ago
EPROM programmers are a whole other discussion, let's not side track @barakandl's fine product thread with it.
I'll be opening up a thread on the Magic code update once I finish off a few tiny things. In the mean time, I'll message you about some of the new enhancements.
9 months later
#19 3 years ago
Quoted from CUJO:
If you are using 6 digit player displays you cannot have the 7 digit display mode dip switch enabled. If you ever roll the game it will try and display the 7th digit which ends up making digit 5 and 6 in the HSTD look corrupted as those two digits are used to decode digit 7. MPU Dip switch 21 should be off when using original six digit displays.
Also clear / reset the memory for HSTD and replays after you change the MPU 6 digit or 7 digit dip switch setting.
#20 3 years ago
barakandl Could I just leave the 6 digit display used for credits/ball in play there and only upgrade the main 4 to 7 digit? thinking about doing this on my space invaders but trying to save a few bucks
#21 3 years ago
Note about the "display interrupt adjust" trim pot. Near the bottom on the mid right there is a blue colored trim pot. This adjusts the rate that the displays are updated. Turning it clockwise will make the displays update more often. When six digit displays are used you want it somewhere from the middle to all the way counter clockwise. When seven digit displays are used you will want it somewhere from the middle to all the way clockwise. Put the game in display test and adjust the trim pot until the displays look the best.
Because seven digit games have more display date to update they can have a perceived flicker when the display interrupt is set slow. The flickering is exacerbated in games like MR/MRs pac that have 7 digit displays and extra playfield display. One side effect to increasing the display interrupt speed is that because you are having the CPU work on the displays more often other things can slow down. Most things will not change speed but some time based features, like the time between the space invaders thumping noise, can vary with the display interrupt trim pot setting.
There is a test pad you can measure the display interrupt frequency at. 320hz-400hz is fine for 6 digit games. 7 digit games 360-450hz is good depending on the game. For 7 digit games best way to set is by adjusting the trim pot during display test until the displays look best. 6 digit games will look good at about any frequency, but too fast may slow down some game features. If I know what game the board is going in I usually dial in the display interrupt for that game before sending it out
Note about Embryon 7 digit mod. This game is wired up like Meteor. The digit 7 drive is hooked up to MPU J1 P7 and the extra J5 plug is not used.
Quoted from piccolohl:
The credit display stays as six digit always.
5 months later
#22 2 years ago
Here’s our Future Spa with the weebly mpu seven digit upgrade. It really is very straightforward to install.
Thanks Andrew barakandl Fabulous product we love it here! Also used it on a Harlem and a Dolly Parton.
A few pictures......
F0280C21-74C3-4B26-83ED-1A8F182AB46E (resized).jpegF0280C21-74C3-4B26-83ED-1A8F182AB46E (resized).jpegD663DD09-6B67-49C2-99FF-02DA44FBBE98 (resized).jpegD663DD09-6B67-49C2-99FF-02DA44FBBE98 (resized).jpegC80BF6D1-8CCF-4F3D-8AF6-1B998FC5EA76 (resized).jpegC80BF6D1-8CCF-4F3D-8AF6-1B998FC5EA76 (resized).jpeg8EFA17AE-906D-43ED-B75C-394272B15DA4 (resized).jpeg8EFA17AE-906D-43ED-B75C-394272B15DA4 (resized).jpeg8C253B5A-B7DE-4CD0-93C2-65805420DA12 (resized).jpeg8C253B5A-B7DE-4CD0-93C2-65805420DA12 (resized).jpeg2D49250E-A2AA-4699-AA5C-D1B5776E08C7 (resized).jpeg2D49250E-A2AA-4699-AA5C-D1B5776E08C7 (resized).jpeg0F499719-A316-4EEB-B1D1-D8174E446C85 (resized).jpeg0F499719-A316-4EEB-B1D1-D8174E446C85 (resized).jpeg0C3459E1-6641-43BC-AC3D-5B38B109A52B (resized).jpeg0C3459E1-6641-43BC-AC3D-5B38B109A52B (resized).jpeg
7 months later
#23 2 years ago
Trying to hunt down a Stern Lectronamo and came across this thread. How is everyone liking their 7 digit upgrades?
I already have xpin 7volution displays in my Paragon, but they don't support classic stern games so this may be just the upgrade im looking for on Lectronamo.
#24 2 years ago
The seller is a platinum trader. Always helpful and great products. Been buying for years.
#25 2 years ago
Quoted from Newforestpinball:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Wow! That's a beautiful machine!! That's a title I wouldn't mind picking up someday.
This page was printed from https://pinside.com/pinball/forum/topic/bally-7-digit-display-expansion-added-to-replacement-mpu and we tried optimising it for printing. Some page elements may have been deliberately hidden.
