I'm having a really annoying problem with a Bally 7 digit display. One of four displays in this game was toasted—literally. It had a hole burned through the PCB. The other 4 displays (including the 6 digit credit/ball) had the 10k digit flickering as can be seen in the video attached. I fixed the 6 digit and one 7 digit by replacing only the 4543 and R44. The display in the video however has had the 10k digit parts Q5, Q11 and R44 replaced along with the 4543 segment driver but still exhibits the same flicker. The new 4543 seems slightly better than the old one but only ever so slightly. The video is of the original part in a new socket on the board. The 9.1K (IIRC) resister at R44 was visibly burnt but was still measuring ~9k when I pulled and replaced it. R44 also shows heat damage on both the displays that I've yet to replace it on. Is there something else in the segment driver circuit that I need to look at? None of the parts check out bad with a DMM but that isn't always foolproof.
