(Topic ID: 202441)
Bally 6803 MPU Board what capacitor?
By ilikepinball
6 years ago
    #1 6 years ago
    I blew one 6803 MPU Board and now I'm trying to fix it.
    As comparison I took a working 6803 MPU board and saw that one board has on right end (the smaller capacitor) a
    25V 470uF (looks orginal, on dead board)
    and the other
    16V 470uF (looks changed, on working board).
    No matter if 16V or 25V?
    Is a 16V fine, or do I need to get 25V capacitor?
    #2 6 years ago
    If the 16V is working, then I wouldn't worry about it. If I was replacing the part I'd go with the 25V.
    #3 6 years ago
    As long as the actual voltage they're connected to is lower than 16, 16 is fine.
    #4 6 years ago
    Thank you.
    #5 6 years ago
    Hi,
    No matter if 16v or 25v.
    Capacitors C8 and C11 are used to filter respectively, the 5 volts line and the unregulated 5 volts line.
    The manual say, C8 : 470 µF 16 v and C11 : 470 µF 35 v
    But they really planned oversized ! You can mount almost any voltage, even 10 volts models would be sufficient.
    On the first board, they used a 25 volts for C8, because they probably no longer had 16 volts on hand.
    In fact, one does not have too much to worry about the voltage, but rather the size of the capacitor so that it fits on the board.
    As they found a 25 volts model small enough, they used it.
    Usually, the higher the voltage, the larger the size of the chemical capacitor.
    But technology is evolving, and there are now 25-volts models, same or smaller than the 16-volts models of a few years ago.
    #6 6 years ago
    Thank you. Good to know.
    Next time I will be prepared
    This page was printed from https://pinside.com/pinball/forum/topic/bally-6803-mpu-board-what-capacitor and we tried optimising it for printing. Some page elements may have been deliberately hidden.
