An interesting dilemma...
My Eight Ball needed display help. I bought two xPin displays with the intent of replacing all 5 at some point ($$).
So the two xPins are in Player 1 and 2 and work perfectly.
The Credit/BIP, Player 3 and Player 4 displays are plasmas. I have numeral issues with these displays however. In Display Test, I get an incorrect sequence (0-1-0-1-4-5~~~~-6-7~~~~-8-9). The tildes are there to represent the fact that when 5 and 7 come up, the displays flicker through several digits, but then lock right back down solid for '6' and '8'.
Sequence is very consistent.
I thought the displays were daisy chained in a way that meant if you had an issue with the MPU everything would be affected. I also understand that a bad decoder or weak resistors could cause strange things, but this is almost as if the top two displays are on one circuit and the bottom three are on a different circuit.
Thoughts?
-scott
