(Topic ID: 313359)
Bally -35 MPU All Displays Flicker
By Knxwledge
2 years ago
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by Knxwledge
    #1 2 years ago
    I've got a Bally MPU I'd like to get working as a spare. Boots fine but all displays and all digits flicker, can try to get a video if my phone camera will cooperate. Driver board is not the problem, swapping MPUs fixes it. Where should I start probing around at? I figure the problem would be with the display blanking signal but this level of PCB repair is not my forte so looking for some advice
    #2 2 years ago
    You can check the display frequency 555 timer but first resolder j1.
    #3 2 years ago
    Cracked solder joints at the header pins maybe? Reflow the headers. Sounds like loose/bad connection.
    #4 2 years ago
    Quoted from slochar:
    Quoted from JethroP:
    I wanna say I did resolder the headers but not sure. Will try that first
    #5 2 years ago
    Flickering displays in this system are 'almost always' dry jointed connector pins o the displays (mainly) and you need to reflow them ALL not just one display because dry joints on one display can cause ALL of them to flicker - they are all basically interconnected (simplifying how they work).
    #6 2 years ago
    no pullup resistors on the displays. open circuit on inputs might cause them to oscillate with other nearby noise. connectors connectors connectors.
    #7 2 years ago
    slochar has it. All displays flickering is typical of the 555 display interrupt generator circuit malfunctioning. Takes a scope to properly test it. However you can try hit and miss by replacing the resistors and capacitors in the circuit.
    #8 2 years ago
    Checked out the display interruptor circuit and found that R21 (36k ohm resistor) was way out of spec. Changed that, tried to boot the MPU but now it doesnt boot, LED stuck on. Im trying the barebones boot method of just having U6, U9 and U11 in. I was swapping chips around with other MPUs, and that circuit isnt related to the reset circuit so gotta figure out that first
    #9 2 years ago
    Quoted from Knxwledge:
    How far out was R21? Games with 7 digit displays actually shipped with a 24k resistor at R21 for faster (420Hz) display interrupt generator.
    #10 2 years ago
    Quoted from Quench:
    Lol I think it was 24k. Would having that smaller resistor in a 6 digit display game cause that flickering?
    #11 2 years ago
    No. Having the smaller resistor value will increase the display interrupt rate. This means the displays will refresh more frequently which should actually reduce the flicker. But the faster interrupt rate then means the CPU time is reduced for doing other 'functions'.
    I would check your connections such as plugs with bad contacts and/or cracked headers as mentioned above. Since this happens with more than one board then I would look at plugs first.
    #12 2 years ago
    Shotgunning and second guessing - replacing random parts on a whim, almost never fixes a problem. It almost always adds additional faults!!!
    #13 2 years ago
    I know your camera might find it hard to capture but we probably need to see a video.
    I've seen people use "flicker" to describe other faults like strobing, ghosting and other artifacts.
    #14 2 years ago
    On these old Bally games, you have to repin all connectors and replace/reflow all headers. You're just chasing your tail if you don't.
    #15 2 years ago
    So here is a prime example. This is a Bally Kiss I'm working on. This is J2 on the lamp driver board.
    #16 2 years ago
    Quoted from Quench:
    Yeah "strobing" might be a better word. It's very rhythmic and consistent, not an occasional flicker. Will take a video of it once I can get it to boot again
    Quoted from G-P-E:
    It actually only happens with this MPU board, I've been testing it in our shop game we keep around for testing purposes. Swapped the MPU back to the working one to work on some displays that came in and it worked great
    Quoted from pins4u:
    I tested for and thought I found an out of spec resistor in the circuit I was advised to look at, how is that shotgunning and second guessing? Thanks for contributing nothing
    This page was printed from https://pinside.com/pinball/forum/topic/bally-35-mpu-all-displays-flicker and we tried optimising it for printing. Some page elements may have been deliberately hidden.
