Hey, this MPU is driving me nuts. I am testing it on the bench, with just the voltages going to J4. When I test it after sitting for a while, the board will flash 3 times. If I reset the power (turn it off and on waiting like 30 secs in between) the led then stays on, however if I jump pins 39 and 40 for U9, it will give me the 3 flashes again.
I've had this MPU for about 10 years, from what I remember I had it in a Cybernaut, and it worked fine (7 flashes etc). I then burned roms for Hot Hand for it, and the LED would stay on. I then realized I had a bad checksum on one of the roms, reburned it, and then I was getting it to 1 or 2 flashes intermittently. I then installed an NVRAM, removed R11, and put zero ohm resistors at CR5 and CR7. Now it does the above.
The board looks nice, there was a small amount of acid damage to it, around the battery sockets, and 1-2 components in the reset section but that was it (just the solder joints look old). The sockets have been replaced (not by me) with machine pinned sockets, and it looks like a decent solder job.
I don't quite understand why when you power cycle it, I get an LED stuck on, then when jumpering it goes through it's 3 flashes. The 6800 U9 looks new, the 6821 U10 looks new. (I can take some pictures of it tomorrow in the sunlight and post them). Is this a capacitor related failure?
There was no trauma to the board at all between when it would get 7 flashes with the cybernaut roms, and when I burned the hot hand roms. What do you guys think of this one?
-Pat
