I have a Nitro Ground Shaker, that will usually power up from a cold start, but after a few minutes if it is turned off, and back on, it only gives a flicker of the led. If you let it set for 10 minutes or so it will usually power up again.
The ROMs have been changed to 2716’s, and the jumpers have been changed. I replaced R11 (open), Q5 (bad), Q1, and VR1 (was 7.5 volt now 8.04 volts). Swapped U7, U9, U10, U11, and put a NVRAM in U8. The mpu voltages are TP5- 5.22 volts, and TP2- 13.22 volts. I also have tried a different solenoid driver board. The voltage on U9 pin 40, is 5.43 volts after the flicker or when it powers up.
Thanks in advance for any help.
