Game: Mr Mrs Pacman.
Condition: No cabinet, purchased as playfield and a box of bits. MPU was toast from battery damage. All other boards of original spec and visually ok.
History:
Story so far is documented here (not necessary to view but will give an insight into the state)...
https://pinside.com/pinball/forum/topic/mmpc-first-ss-second-pin-coffee-table
The issue:
Upon power up the game boots, all displays function correctly. Can add credits and start a game but not in a position to go further as assemblies not installed.
If I leave the game in attract mode it will wait the required time then start the attract sequence. Once the attract sequence has finished all hell happens with the feature lamps. It is like a Christmas tree on acid.
This is with LEDs and incandescent lamps. It is not strobing or ghosting it is like a scene from poltergeist.
After a few minutes all lamps associated with the Main Lamp Driver Board stop working.
What have I tried:
Re-flowed all connectors on all boards.
Tested continuity across boards from on PCB locations.
Ran the game without Aux Lamp Driver Board attached and the same happens (without the Aux lamps staying on)
Ran the game without Main Lamp Driver Board attached and the Aux lamps do as expected in attract mode and seem they would indefinitely.
Ran the Game with main lamp board only one header J1, J2 or J3 attached - still have same issues.
Checked the playfield harness about 5 times for shorts.
Checked header connectors for correct wire locations and colours.
I assume that as the Aux Lamp Board is receiving instruction and acting correctly that the MPU is also behaving.
Does this sound like an issue with the Main Lamp Driver Board or am I barking up the wrong tree ?
What should I try next ?
Thanks,
Guy
