Can anybody tell me if is is necessary to have the header pins soldered on in order to bench test a -35 MPU. I am working on a corrosion repair and I have cleaned/neutralized/removed the corrosion, removed and replaced all of the components in the corrosion repair kit, plus a few more that were affected, replaced 3 IC sockets in the affected area, U7, U8 and U11. I haven't installed the new header pins. I have bench tested the MPU and I get the dreaded solid always on LED.
